Old 11-05-2007, 07:19 PM   #1
Eibwen
Tap a three way switch
I have a three way light switch box that I expanded to a double gang switch for a new unrelated set of lights over the stove since we got rid of the range hood.
I want to power the new lights from the three way switch which I can do until the OTHER three way switch on the far side of the room is turned off.
Is there a way to do this without running a new hot lead for the new switch?
Sammy is offline   Reply With Quote
Old 11-05-2007, 08:23 PM   #2
Union Electrician
goose134's Avatar
Sounds like you're tapping in at the switch leg side of the 3- way. You are going to have to run a new hot over there. Maybe from the basement?
goose134 is offline   Reply With Quote
Old 11-05-2007, 09:09 PM   #3
Eibwen
Yeah I'm on the other side of the room from the feed.
I can live with it the way it is since we rarely use the other three way switch.
Was just wondering if I was missing something.
Old 11-06-2007, 03:21 PM   #4
Electrician philosopher
Naw, you didn't miss anything...ain't electricity fun?
Andy in ATL is offline   Reply With Quote
Old 11-06-2007, 04:16 PM   #5
joed's Avatar
If you only have three wires + gound in the box then you can not do it.
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 10:34 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
Ceiling Fixture / Switch Wiring gregger Electrical 1 10-21-2006 08:47 PM
When Bulb blows, Dimmer Switch Blows mAv19 Electrical 2 05-26-2006 04:52 PM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 03:53 PM
