Tap Off Service Entry Line - Electrical - DIY Chatroom Home Improvement Forum
Old 07-13-2012, 10:23 PM   #1
This older panel from 1960s had wires connected to each of the service entrance lugs which went to a 30 amp breaker and out to the AC unit. Is there an issue with "tapping" off the lug with these wires and providing an additional breaker? Also, is there any issue with the numerous neutral wires connected to the same lug?
mk00 is offline   Reply With Quote
Old 07-13-2012, 10:35 PM   #2
Master Electrician
the neutrals should each have their own lug, you can't put two wires in the same lug unless it's rated for that use, normally the lug will be slightly egg shaped. I doubt yoru panel has them.
i should edit this to say that's current code to the best of my knowledge, no idea what it was in 1960.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 07-13-2012, 11:16 PM   #3
" Euro " electrician
frenchelectrican's Avatar
That is the old school Pushmatic breakers I have see it pretty often when I was living in Wisconsin.
Anyway do this pushmatic load centre do have main breaker in the panel or you have seperated main breaker somewhere else ?
IMO it is the time to do the replacement of the panel I know Pushmatic useally not a major issue but to find replacement parts is getting harder espcally with any two pole breaker above 60 amp.
Unforetally They are not rated for mulit wire in a hole so it have to be seprated it.
Merci,
Marc
Old 07-14-2012, 06:04 AM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,968
And NO, those #10's on the main lugs are NOT cool.
I agree, it is time for a panel change. BIG time.
Speedy Petey is online now   Reply With Quote
The Following User Says Thank You to Speedy Petey For This Useful Post:
frenchelectrican (07-14-2012)
Old 07-15-2012, 10:26 AM   #5
Merci,
Marc
No main breaker outside or in the panel...
Old 07-15-2012, 09:28 PM   #6
If you can take a photo of the whole panel I think you did have a split buss panel so the upper third of the panel is " main " section while the rest is lower buss part aka lighting section so there is couple clues you can find.
First of all the main breaker will have 100 amp stamped on side of the pushmatic handle that number you can not miss it at all if there none there then look for 50 amp breaker which it will shut off the lower two third section of panel that is a split buss panel.
Then again please do post the whole panel we can able tell you that if that is split buss panel.
Merci,
Marc
Old 07-16-2012, 02:44 PM   #7
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
What is the smaller box to the lower left? Is the pushmatic panel fed from that panel? It looks like a 100 A breaker in there but I can't tell from the small pictures. My eyes are getting kind of old.
John
jrclen is offline   Reply With Quote
DIY Comedy--PVC for main water line? Daulton Plumbing 8 03-23-2011 09:03 AM
Do I need a new service line? BataviaJim Electrical 8 03-04-2011 02:10 PM
Service line from house to garage.... question Todd-sta Electrical 24 11-10-2008 12:23 PM
Grounding for two service entrances to same house. jogr Electrical 18 09-24-2008 10:31 AM
2x100a sub on service main jambud Electrical 17 03-12-2008 09:31 AM
