Tap Or New?? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-14-2012, 04:45 PM   #1
tap or new??
Can I Tap Into Existing Panel To Power A 2 Family Detached House..
house has 8 apts and a washer and dryer // 2 meters 200 amps each and oil fired furnace ..
detached 2 family will be 2 bed,1 bed room 2 washers and 2 dryers..all apts have electric stoves and only the gas heat..
or do i have a pole set and run new service to the detached building
angelo9999 is offline   Reply With Quote
Old 04-14-2012, 05:45 PM   #2
Rewards Points: 1,512
You need to do a load analysis to see if one of the existing services is big enough (amperes) to serve both a portion of the existing 8 family building and the new 2 family building.
Note that the existing services may be inadequate to begin with; they would be grandfathered to continue to serve the existing 8 family. Any significant addition would require being brought up to modern code. Generally an apartment needs a 60 to 100 amp panel or subpanel depending on size and local code.
So by putting in a new service for the new building the existing services can be left as-is.
Old 04-14-2012, 06:02 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
The Following User Says Thank You to Speedy Petey For This Useful Post:
HIVOLT (04-14-2012)
Old 04-14-2012, 06:04 PM   #4
What you need to do is contact a qualified electrician. He can give you a proposal as to what would need to be done and what he would charge. Agree on a price and have him do the work.
This is NOT DIY work.
The Following 4 Users Say Thank You to Speedy Petey For This Useful Post:
HIVOLT (04-14-2012), Jim Port (04-14-2012), k_buz (04-14-2012), plummen (04-14-2012)
Old 04-14-2012, 06:29 PM   #5
Master Electrician
Rewards Points: 3,870
Yeah, but I just changed three single pole switches without any extra help!
brric is offline   Reply With Quote
Old 04-14-2012, 08:56 PM   #6
Licensed electrician
Rewards Points: 1,616
Sounds like you will be good to go after staying at the Holiday Inn.
