Tap Into An Outlet With Black Wires To Wire A New One - Electrical - DIY Chatroom Home Improvement Forum
Old 12-07-2011, 08:28 PM   #1
tap into an outlet with black wires to wire a new one
In my attic I want to tap into an exsisting outlet to wire a new one. The exsisting outlet is wired with black wire, I never seen this before. I am thinking that the black wire means alway hot. But inside the sheath or black wire cover is a black and white wire. I want to wire an new outlet from this outlet.
diggherwild is offline   Reply With Quote
Old 12-07-2011, 09:00 PM   #2
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Is there a bare copper wire along with the black and white insulated wires?
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 12-07-2011, 09:09 PM   #3
Licensed electrician
Rewards Points: 1,020
What does the existing cable feed. Certain circuits cannot be shared with other areas.
Old 12-07-2011, 09:19 PM   #4
UAW SKILLED TRADES
Stubbie's Avatar
Ok I see you went off line. Here is why I asked the question about the black sheathed cable with black and white insulated wires.
Stubbie
Replacing outlet - no ground wire clydesdale Electrical 17 12-18-2011 03:29 AM
Central Vac Wiring scottycarroll Electrical 12 09-16-2011 06:31 PM
Converting switched outlet to unswitched.. Blivit Electrical 8 07-11-2011 08:07 AM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 06:13 PM
4 way switch confusion Richo Electrical 10 04-09-2009 08:11 AM
