Old 03-11-2011, 05:49 PM   #1
Tanning bed 3wire cord to 4wire
So I'm trying to convert the original three wire cord to a 4 wire. The problem I'm running into is, in the original cord, there is a white, black and green wire, and that's it. the new cords has black, white, green, and red. i don't know what I'm supposed to do with the red cord. There are only two places to connect the wires, one for the white and one for the black, and then the green screws to the frame.
please help!
bwgberg is offline   Reply With Quote
Old 03-11-2011, 05:53 PM   #2
Licensed electrician
What is the voltage of the tanning bed? What are you trying to plug it into? Why are you changing the cord?
Old 03-11-2011, 06:00 PM   #3
Its 220v, I don't have a three prong 220v outlet, only a four prong 220v.
Old 03-11-2011, 06:53 PM   #4
If the bed is straight 240 it only needs two hots and a grounding conductor.
Most 240 circuits are dedicated for things like the water heater, stove and dryer. Are you trying to use one of these circuits for the bed also?
Old 03-11-2011, 06:57 PM   #5
I'm trying to use the dryer outlet. The bed says it's 220v.
Old 03-11-2011, 07:12 PM   #6
Semi-Pro Electro-Geek
Connect black to black, green to green, and the red wire in the cord to the white terminal in the bed. Cap off and do not use the white wire in the cord.
mpoulton is offline   Reply With Quote
Old 03-11-2011, 07:18 PM   #7
Master Electrician
The dryer is a 120/240 volt circuit.
brric is offline   Reply With Quote
Old 03-11-2011, 07:19 PM   #8
Awesome thanks
Tags
cord, tan, tanning bed, wire
Ceiling power cord kerry42 Electrical 18 11-03-2009 04:58 PM
Is my extension cord OK? MT Stringer Electrical 4 10-20-2009 08:25 AM
Ele hot water tank and welder sharing circuit wazeaz Electrical 68 03-19-2008 08:17 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 10:58 PM
Do I have a 30 amp or 70 amp welder. And help wireing it. Tmb9862 Electrical 17 12-04-2006 10:21 PM
