Tanning Bed 12/2 Or 12/3? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-22-2013, 06:16 PM   #16
Rewards Points: 184
Hello Marc,
Tested the voltage today and it read at 240 volts. Should I use the transformer?
Originally Posted by frenchelectrican View Post
That is correct however as I mention before I am wating for OP reply on the house actual voltage so once I know the actual voltage then either they can keep the autotransfomer or not depending on what the voltage level it is in there now.
Merci,
Marc
stevekem is offline   Reply With Quote
Old 08-22-2013, 11:43 PM   #17
" Euro " electrician
frenchelectrican's Avatar
Before you turn on this tanning bed is there is a second plug after the transfomer ? if so you can check the voltage after the transfomer to make sure it is downstep a little to about 225 volts or so if that the case go ahead and plug it in ( on between the transfomer and tanning bed )
If not getting 225 volts if reading way too high or too low, stop right there I will assit you on more on that.
Merci,
Marc
Old 08-27-2013, 09:09 PM   #18
Rewards Points: 184
Hi Marc,
Volts measured 228 at end of transformer.
Merci,
Marc
Old 08-28-2013, 12:24 AM   #19
Originally Posted by stevekem View Post
Hi Marc,
Bonjour Stevekem.,
After you verified then you should be ok with it.
It will read a little high when the autotransfomer is unloaded but once it loaded up it will drop down to the sweet spot so you should able use it without issue at all.
( Note: it will proboly drop down to 222 or so volts when you turn the tanning bed on full load.<that with 16 volt buck setting >))
Bon Chance.
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
stevekem (08-28-2013)
Old 08-28-2013, 10:31 AM   #20
Rewards Points: 184
Ok, great. Thanks for the help Marc!
Bonjour Stevekem.,
Bon Chance.
Merci,
Marc
12/2 vs 12/3 Savinmoney Electrical 6 10-09-2012 01:11 PM
pulling a 12/2 run from 12/3, how to? SocalPaddy Electrical 23 10-24-2011 01:15 AM
Replacing 12/2 with 12/3 behind wall iya Electrical 8 06-20-2010 07:51 PM
Afci & 12/2 golddog Electrical 11 12-10-2009 11:23 AM
12/2 vs. 12/3 Suncrest79 Electrical 2 03-07-2009 02:42 PM
