Tanning Bed - Electrical - DIY Chatroom Home Improvement Forum
Old 06-21-2011, 09:00 PM   #1
Tanning Bed
I have a tanning bed that needs to run off a 20 amp breaker. The receptacle i plugged it into is on a GFIC when the bed is turned on it trips the GFIC receptacle . What can I do to fix my problem.
ces62 is offline   Reply With Quote
Old 06-21-2011, 09:29 PM   #2
I=E/R
a7ecorsair's Avatar
Is this tanning bed new? If not, did it work in some other location?
a7ecorsair is offline   Reply With Quote
Old 06-21-2011, 09:45 PM   #3
Master Electrician
Rewards Points: 3,870
120 or 240 volts?
brric is online now   Reply With Quote
Old 01-20-2013, 05:33 PM   #4
used and it is a 240 volt did work in another location
timleeb is offline   Reply With Quote
Old 01-20-2013, 05:49 PM   #5
JPL
You're plugged into a 110vac gfi. It need 220/240. Hire an electrician.
JPL is offline   Reply With Quote
Old 01-20-2013, 08:43 PM   #6
Rewards Points: 13,712
Someone would have had to have rewired the cord or change the plug on the end for you to even be able to have plugged it into a reguler outlet if it's really 220 volts.
Old 01-20-2013, 08:52 PM   #7
dmxtothemax's Avatar
Rewards Points: 5,352
Have you plugged something else into this circuit ?
Does it work ok !
dmxtothemax is offline   Reply With Quote
Old 01-20-2013, 09:16 PM   #8
" Euro " electrician
frenchelectrican's Avatar
Just give you a head up with the tanning beds they are pretty picky on voltage and you will have to check the connection diagram very carefull due some will say only 3 conductor and some will say 4 conductor hook up.
Majorty of them I ran into useally set up for 240 volt useage it is super rare to see it set up for 120 volt operation due the wattage of tanning bed is pretty high useally 1000 to 2400 watts depending on the numbers of bulbs and what else on that unit.
Most of the time I useally run into commercal verison and they are very specfic on useing correct voltage otherwise it will not function properly.
Merci,
Marc
Tanning bed 3wire cord to 4wire bwgberg Electrical 7 03-11-2011 06:19 PM
