Tankless Water Heater Install. - Electrical - DIY Chatroom Home Improvement Forum
Old 04-14-2012, 11:32 PM   #1
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
tankless water heater install.
Finally got a chance to install our tankless water heater. It was installed at one time but had to be put back in after the new breaker panel was installed. Back in service and working great. Did not have any green so I have to grab some or mark the other end green.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
The Following User Says Thank You to rrolleston For This Useful Post:
k_buz (04-15-2012)
Old 04-14-2012, 11:48 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I don't know if I've ever wired one of these...
Are the controls being fed with 4 240V circuits? What are they for?
Old 04-14-2012, 11:57 PM   #3
those electric tankless heaters take a ton of juice to operate
itsnotrequired is offline   Reply With Quote
Old 04-15-2012, 12:05 AM   #4
rrolleston's Avatar
Four elements require four 250v feeds. Simple to install and they work great more convenience than cost savings. Luckily this utility/laundry room is a middle point for all our hot water usage and makes it a good spot for the heater.
Old 04-15-2012, 12:08 AM   #5
yes, they cut down on the overall bill but man, do they suck the juice while running. what is yours rated, 100A?
Old 04-15-2012, 12:09 AM   #6
k_buz's Avatar
I've wired small insta-hot units and commercial dishwashers with 90A booster heaters, so I guess a tankless water heater would be no different.
Old 04-15-2012, 12:13 AM   #7
rrolleston's Avatar
Yes they do this model uses 120amps at full usage but we have never had it at full usage since it only uses enough energy to get the water to the desired temp. Was testing it out and the average faucet uses about 25-30%. I remember when we first bought it and all faucets going it was using about 80% at max usage in our home.
Old 04-15-2012, 12:16 AM   #8
good point, it isn't an 'all or nothing' device but i would need to put in a dedicated sub at my place!
Old 04-15-2012, 12:23 AM   #9
rrolleston's Avatar
This model came with a murray sub panel but it required a 125 amp breaker be put in our panel and the new murray/siemens panels only allow 110 amps per stab. So I used the breakers in this panel instead of using the sub panel. Guess I can find a use for someday. And I re purposed some of the #2 wire that used to feed the sub panel as a ground wire to the frame of our home and water main.
Old 04-15-2012, 12:27 AM   #10
k_buz's Avatar
I see that you have the grounds and neutrals separated in this panel. Did you do that for the heck of it, or is this a sub panel?
If its a sub panel, the GECs should be going to the main disco.
Old 04-15-2012, 12:30 AM   #11
rrolleston's Avatar
Yes it's a sub panel. Main panel is about 60 feet away in our garage.
I also prefer to keep the grounds and neutrals separate in a main panel.
Old 04-15-2012, 12:34 AM   #12
k_buz's Avatar
That water ground then should be going to the main panel, unless this is a second water ground.
Old 04-15-2012, 12:37 AM   #13
rrolleston's Avatar
A ground conductor from my main panel in a detached garage to a water pipe in my home?
k_buz (04-15-2012)
Old 04-15-2012, 12:41 AM   #14
k_buz's Avatar
You have proven me wrong...your installation is correct. This has been another episode of "different installation practices in different parts of the country".
It is a very rare occurrence around here to have the main service in a detached garage, and a subpanel in the house.
Carry on.
Old 04-15-2012, 12:41 AM   #15
when you say 'separate' do you mean on separate bars in the main panel? or is the neutral insulated at the main?
The Following User Says Thank You to itsnotrequired For This Useful Post:
brric (04-15-2012)
Water heater install Missouri Bound Plumbing 5 01-27-2012 11:39 PM
REplacing water heater - PV, DV, or Tankless? curls00 Plumbing 5 12-09-2010 01:21 PM
Need to run gas line to Tankless Water Heater. anonymouscuban Plumbing 2 04-16-2010 03:56 PM
Installing a Tankless Water Heater infoiam Plumbing 4 11-10-2008 10:59 PM
