Tankless Hot Water Heater Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 02-16-2012, 12:40 PM   #1
Tankless hot water heater wiring
Can the same double pole 20 amp breaker for our old hot water tank be used to wire a tankless water heater. We live in a mobile home with a 100 amp service.
rbaker80 is offline   Reply With Quote
Old 02-16-2012, 01:00 PM   #2
Rewards Points: 3,130
If it's an electric tankless, not a chance. They use a LOT of power, maybe even more than your service is rated for. If it's a gas tankless, the only electricity needed is for the control circuitry. Mine is 110VAC and has a regular three-prong plug.
Old 02-16-2012, 01:04 PM   #3
Rewards Points: 13,960
What amperage is the tankless water heater?
Old 02-16-2012, 01:50 PM   #4
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
We had to updae our homes electric service for our tankless water heater. 120amp draw at full usage. Hopefully live in the south and have a really small unit or it's gas.
rrolleston is offline   Reply With Quote
Old 02-16-2012, 03:18 PM   #5
I=E/R
a7ecorsair's Avatar
Tankless electric water heater require a lot of power and I don't think your 100 amp panel can support it. I looked at tankless whole house units on Home Depot and the manufactures recommends a 200 amp panel because the unit needs 80 amps.
Do you have LP or natural gas to your house? You may want to look into those are just replace you water heater with a similar unit.
a7ecorsair is offline   Reply With Quote
Old 02-16-2012, 04:49 PM   #6
I=E/R
a7ecorsair's Avatar
Another idea would be to use two Point of Use heaters like:
http://www.lowes.com/pd_27000-1136-GL6_4294859100_4294937087_?productId=3256918&Ns=p_ product_prd_lis_ord_nbr|0||p_product_qty_sales_dol lar|1&pl=1&currentURL=%2Fpl_Point%2Bof%2BUse%2BWat er%2BHeaters_4294859100_4294937087_%3FNs%3Dp_produ ct_prd_lis_ord_nbr|0||p_product_qty_sales_dollar|1 &facetInfo=
Use one in the kitchen and one for the bath which may support the laundry but not at the same time for long.
You could change the breaker to two 120v 20 amp breakers to power them.
Tankless water heater to pre-heat incoming water matthet Plumbing 35 01-06-2017 12:39 AM
Wiring tankless hot water heater Jarrod3154 Electrical 8 02-26-2011 12:34 PM
Tankless Water Heater welshie Plumbing 12 03-03-2010 12:46 PM
Tankless water heater - NEED HELP! LakersFreak Plumbing 39 11-16-2008 08:49 AM
Tankless water heater questions shadango Plumbing 8 11-12-2008 07:10 PM
