Tandem Vs. Two Pole - Electrical - DIY Chatroom Home Improvement Forum
Old 04-11-2013, 05:04 PM   #1
Tandem vs. Two Pole
Hi, I'm replacing an FPE load center and breakers (picture attached) and had a question on breaker replacement type. There is a metal bracket across two of the 15amp breakers and two 30amp breakers.
What is the preferred/proper replacement? Can I use two separate single pole breakers of equal amperage or do I need a tandem with both poles on the same breaker? I'm not sure what this metal bracket was designed to accomplish....
dfelb8 is offline   Reply With Quote
Old 04-11-2013, 05:08 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
The metal bracket makes the breaker a 2 pole breaker.
You can not replace with single pole breakers unless you do not need the 240v power.
Old 04-11-2013, 05:17 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
Those are handle ties.
Just replace them with two-pole breakers.
Old 04-11-2013, 06:44 PM   #4
So for clarification, the product descriptions (Square D QO's) below offer the same capability and the tandem just uses half the space?
Or, does the tandem style not offer 240 capability?
Product descriptions:
Option 1: 2 - 15 AMP Single-Pole Tandem Circuit Breaker
Option 2: 15 AMP 2 Pole Circuit Breaker
Old 04-11-2013, 07:12 PM   #5
Sparky
Rewards Points: 510
Tandems do not allow 240V, because they're only connected to one of the 2 busbars
Techy is offline   Reply With Quote
Old 04-11-2013, 09:00 PM   #6
Rewards Points: 992
Except for the tandems that are connected to both busbars.
Might not be available for your panel, but I have used double breakers that give two 240v circuits by combining pairs of half size breakers.
Toller is offline   Reply With Quote
Old 04-11-2013, 09:42 PM   #7
Sparky
Rewards Points: 510
More commonly referred to as 'quad' breakers, not tandem.
Old 04-12-2013, 06:46 AM   #8
Master Electrician
Rewards Points: 3,964
Use a new load center large enough to negate the consideration of tandems.
brric is online now   Reply With Quote
Old 04-12-2013, 08:20 AM   #9
Rewards Points: 349
There really is not much debate to have here. Do what SP says, using your "option 2". And buy a panel large enough to avoid needing to use tandem breakers. Nuff said.
al_smelter is offline   Reply With Quote
Old 04-12-2013, 02:16 PM   #10
Rewards Points: 192
Does it look like the two double pole breakers are tied together? Numbers 17, 18, 19, 20.
Thanks,
Rick
bcgfdc3 is offline   Reply With Quote
Old 04-12-2013, 08:11 PM   #11
jbfan's Avatar
Rewards Points: 650
Thanks,
Rick
No. 6\7 is a 2 pole breaker, and 18\19 is a 2 pole breaker, or connected by the breaker tie.
Single Pole vs. Double Pole Thermostat dforeid Electrical 14 08-26-2012 08:12 AM
Can a T104 dual pole timer be used as a single pole installation? illuminate Electrical 6 06-13-2012 05:33 PM
Double pole breaker used as single pole WonderingOne Electrical 11 11-30-2010 12:37 AM
240V 2 pole 1/2 inch GE breakers? Isaac-1 Electrical 12 02-09-2010 11:21 AM
Slimline Vs. Tandem Vs. Double Pole turd hurder Electrical 1 06-23-2008 03:00 AM
