Old 10-22-2004, 07:58 PM   #1
Unregistered
Guest
Posts: n/a
Question
Tandem Fluorescent circuit
I have an aquarium light system runing 2 x 30" fluoro tubes on one switch(tandem), and want to convert it to run 2 tubes seperately. is this possible? if so any help is greatly received.....
Old 10-22-2004, 11:16 PM   #2
If I understand you correctly... They have to be wired up separately with each different switch being the different power source for each light.
Hammertime is offline   Reply With Quote
Old 11-14-2004, 04:33 AM   #3
Unregistered
Guest
Posts: n/a
You will need to purchase two single lamp ballasts rated for lamp size. Add an extra switch to seperate the ballasts/lamps.
Old 11-15-2004, 12:09 AM   #4
Contractor
Unregistered is right. You will need two separate lamps. You CAN do what you want to do but I don't think that you want to go through the aggrevation.
Teetorbilt is offline   Reply With Quote
Old 11-16-2004, 11:17 PM   #5
I do believe that's what I said.
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 04:34 PM
Finding "Champion" brand circuit breakers? Jemo Electrical 5 03-11-2007 01:28 PM
Conflicting Circuit Info!?? BenBil Electrical 9 01-15-2007 09:26 AM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 09:09 PM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 11:05 PM
