-   -   Tandem Fluorescent circuit (http://www.diychatroom.com/f18/tandem-fluorescent-circuit-223/)
Unregistered 10-22-2004 07:58 PM
I have an aquarium light system runing 2 x 30" fluoro tubes on one switch(tandem), and want to convert it to run 2 tubes seperately. is this possible? if so any help is greatly received.....
Hammertime 10-22-2004 11:16 PM
If I understand you correctly... They have to be wired up separately with each different switch being the different power source for each light.
Unregistered 11-14-2004 04:33 AM
You will need to purchase two single lamp ballasts rated for lamp size. Add an extra switch to seperate the ballasts/lamps.
Teetorbilt 11-15-2004 12:09 AM
Unregistered is right. You will need two separate lamps. You CAN do what you want to do but I don't think that you want to go through the aggrevation.
Hammertime 11-16-2004 11:17 PM
I do believe that's what I said.
