Tandem Breaker Positions In Main Service Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 05-10-2012, 04:22 PM   #1
Rewards Points: 135
Tandem breaker positions in main service panel
I have a Siemens W3040B1200CU main service panel. The diagram on the inside of the door indicates 5 bottom positions on each pole- total of 10- for tandem breakers. There are currently 6 tandem breakers but they are located in the upper positions. Do tandem breakers have to be in the exact positions indicated on the diagram and why? I believe the previous owner replaced an old panel with this one. The wires are definitely not long enough to put the circuits on tandem breakers in the bottom slots.
elmaur is offline   Reply With Quote
Old 05-10-2012, 04:24 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Yes, they have to be positioned where the diagram shows. If the wires are too short, splice some wire on to extend them to the bottom of the panel.
Old 05-10-2012, 04:31 PM   #3
Rewards Points: 135
Why do they need to be in those exact positions? Splicing with wire nuts? and is this code compliant?
Old 05-10-2012, 04:40 PM   #4
k_buz's Avatar
The need to be installed in those locations because that is how the panel was listed an approved to be sold.
Wirenuts in a panel are perfectly acceptable.
Old 05-10-2012, 04:47 PM   #5
Rewards Points: 135
My inquisitive mind still would like to know why a panel is approved and listed for tandem breakers in specific positions. I am not an electrician. I was a low voltage contractor for 25 years. Can someone give me a technical explanation?
Old 05-10-2012, 04:49 PM   #6
k_buz's Avatar
It could be for a variety of reasons.
could be that the buss is designed to only allow tandems in those locations, and the reason they are in the upper spots is that the breakers were modified
could be that that is what Siemans speced to the listing agencies and that is how it was approved
Old 05-10-2012, 04:53 PM   #7
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
You may also want to check and see if the panel was reversible and if it was reversed. Siemens Murray make many panes that can be reversed so it can be either bottom or top feed. So it is possible that it's done correctly.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 05-10-2012, 05:39 PM   #8
Rewards Points: 135
My main service connects at the top. Looking at it I do not think it was reversed but I am not 100% certain what I am looking for. What I can tell you is the bottom 10 positions- 5 on each pole- have short fork like copper connections for the breakers and the remaining upper positions are flat copper contacts. I am guessing this follows what the diagram is indicating for the positions for tandem breakers?
Old 05-11-2012, 12:27 AM   #9
" Euro " electrician
frenchelectrican's Avatar
AFAIK the modern Siemens breaker box with tandem breakers the quickest way to tell is look at the phase bussbars and with tandem breaker postion the bussbar will be notched so that is the area you can use the tandem breakers.
They useally are on the bottom 5 rows if the main breaker or main lug is top so if the main breaker or lug is reversed aka bottom feeders then it will be reversed.
Merci,
Marc
Old 05-11-2012, 04:42 AM   #10
Rewards Points: 135
Merci,
Marc
I referred to the bussbar connection as "forked", you say notched. I am sure we are talking about the same thing. So the bottom 5 rows are occupied by 2 pole breakers for hot water heater, electric dryer, electric stove, hvac, etc. and the tandem breakers are in the upper rows. I thought I read somewhere that tandem breakers can only connect into their designated spots because of the way the connection is configured but apparently on this panel they can plug anywhere. Anyway is there a danger in having the tandem breakers and 2 pole breakers not where they are supposed to be? It's been that way for at least the 1 1/2 years I've lived here.
Old 05-11-2012, 06:24 AM   #11
Pure Genius
Rewards Points: 150
They make cheater tandems. These will go anywhere in a panel. They also make tandems that have a hook on them that will only go into their designated space on the buss bar.
Dierte is offline   Reply With Quote
Old 05-11-2012, 06:32 AM   #12
Rewards Points: 135
CTL panels have a rejection feature to prevent tandem breakers from being used in the wrong location. My Seimens panel must be a CTL panel since it has the notched bussbar connection in the positions indicated for tandem breakers but I have tandem breakers in locations not specified for tandem breakers. Does this mean the tandem breakers are non CTL and if so is this bad?
Old 05-11-2012, 06:35 AM   #13
Rewards Points: 135
You responded while I was typing. So I have cheater tandems. All I need to know now is it a hazard? Is it code compliant?
Old 05-11-2012, 08:23 AM   #14
Licensed electrician
Rewards Points: 1,010
It would not meet the code having the non-CTL tandems in the panel or in the wrong locations.
Old 05-11-2012, 02:28 PM   #15
Rewards Points: 718
if it is like sqd there are 2 types of tandem breaker one is listed for ctl panel (us panels, have a hook so ti can be used only at specific places) and the other non ctl (canadian panel, doesn't have hook, they are exactly like single pole breaker), but the canadian ones can fit any spaces on the us panel
carmusic is offline   Reply With Quote
Main Service Panel to 2 breaker panels - I can imagine you all rolling your eyes kalus Electrical 22 03-23-2012 03:09 AM
Outside breaker, inside main breaker panel, so is it a sub? CPF Electrical 29 02-01-2012 11:28 AM
new sub panel BlueBSH Electrical 11 01-22-2012 09:28 AM
Adding ground bar to main panel WoodworkerDave Electrical 6 09-27-2008 05:52 PM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 06:44 PM
