Old 08-01-2012, 10:08 AM   #1
Jack of all - master none
hyunelan2's Avatar
Tandem Breaker - Box incompatible?
Hello all. I installed 2 new outlets in garage, each on their own circuit (GFCI protected outlets, 12g THHN in conduit). I wanted to use a tandem breaker so that these two outlets were easy to identify in the box. Upon trying to install the breaker, I think that perhaps my box is not compatible with tandem breakers - or I got the wrong breaker. From what I've read, the bus stabs are not notched, so they are not compatible/allowed to be used with tandems.
Just double checking here. I can get the breaker in, but it doesn't seat all the way, so that's wrong. I've got room to put 2 single pole 20a breakers, so it's not the end of the world, just not what I wanted.
(click image for larger picture - tandem and single pole 15a side-by-side)
hyunelan2 is offline   Reply With Quote
Old 08-01-2012, 10:23 AM   #2
Super Moderator
What brand box---what do the existing breaker have printed on them---
oh'mike is online now   Reply With Quote
Old 08-01-2012, 10:26 AM   #3
hyunelan2's Avatar
Square D box, don't know the model (installed in 2002).
Existing breaker is pictured (15a):
Type HOM
DP-4075
Tandem is:
Type HOMT
DP-4075
CTL
Upon further reading, I need to look at the diagram in my box. It is possible that there are slots that allow tandems, they are just all in use by standard breakers.
Old 08-01-2012, 02:07 PM   #4
The box model number should be on the inside of the door.
It will be something similar to
HOM12M100C or
HOM1224M100TC, etc.
Oso954 is offline   Reply With Quote
Old 08-01-2012, 02:13 PM   #5
hyunelan2's Avatar
HOMC40UC
Series 501
Type 1 Enclosure
The HOMC40UC is no tandems allowed. This should be a lesson in do your homework before buying supplies. Looks like I'll need to go pickup 2 standard 20a breakers.
Separate 110 and 220 receptacles on 2-pole 220 V Square D GFI breaker sunrise Electrical 1 05-13-2012 08:27 PM
Tandem breaker positions in main service panel elmaur Electrical 14 05-11-2012 02:28 PM
small voltage on circuit with breaker off jasonmechler Electrical 3 08-24-2009 09:52 AM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 09:59 PM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 06:44 PM
