#1 |
Tandem Breaker
Does anyone know of a tandem breaker that will work in a Federal Pioneer stab-lok BE-120-40 Panel.
#2 |
Electrician
Tandem Breaker
What type of tandem do you want, almost all federal pioneer breakers are the skinny type and you can get them in 2 pole as well.
Are you located in Canada, i am assumeing due to the type of panel you have. |
#3 |
Tandem Breaker
I am in Canada, the electrical supplier told me there are no tandem breakers that will work in said panel. Panel is full need to install a 240v relay for heated floor
#4 |
Electrician
Tandem Breaker
He would be correct, like i said most breakers for that panel are the size of a tandem breaker(1/2" or so thick) of other panels.
Your two options are to replace the panel you have now with a bigger one, or install a subpanel in order to get the room you need. |
| The Following User Says Thank You to darren For This Useful Post: | 184 (05-06-2010) |
| Display Modes | |
| 20 amp GFCI breaker pops when pool pump is turned on. | jagrunner | Electrical | 11 | 03-19-2010 05:31 PM |
| Tandem breaker use | pomelo | Electrical | 3 | 03-18-2010 09:17 AM |
| tandem breaker | MikeyP | Electrical | 11 | 06-29-2009 02:48 PM |
| Tandem Breaker and Circuit(s) | whowadat | Electrical | 1 | 01-09-2009 05:13 AM |
| Tandem breaker | rusty_5620 | Electrical | 10 | 09-26-2007 04:03 PM |
