Tandem 220v Breaker? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-21-2012, 10:39 AM   #1
tandem 220v breaker?
I want to add a 220 line to an already full 100 amp panel. I know I can combine a few breakers with tandems to free up space. My question is this, I currently have a 220 breaker for my AC, is there a tandem breaker for 220 circuits? So I can just split the circuit I already have?
rknerem is offline   Reply With Quote
Old 01-21-2012, 10:41 AM   #2
joed's Avatar
Rewards Points: 11,534
They are usually quads if they supply 240 volts.
Old 01-21-2012, 10:41 AM   #3
Licensed electrician
Rewards Points: 1,010
Not all panels are listed for use with tandems.
Some brands may have a quad 240 breaker.
Old 01-21-2012, 10:50 AM   #4
The current 220 breaker is in slots that are marked to accept tandem breakers. So a quad breaker will create two separate 220v circuits the same way a tandem creates two 110.
Old 01-21-2012, 11:36 AM   #5
Julius793's Avatar
Yes usually the 2 inner is for one line and the 2 outer are for the other line
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-21-2012, 01:08 PM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
What are the amperages?
"220" is a homeowner/handyman term, and is only half the equation. The amperage is the other.
Converting a 220V two-gang outlet to 110V kevindd992002 Electrical 17 09-30-2011 07:17 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
Murray main lug center - what type of tandem breaker? cl or ncl? plove79 Electrical 4 09-01-2010 09:08 PM
Breaker problem jdhar Electrical 11 06-10-2009 02:18 AM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 09:59 PM
