Old 10-19-2011, 08:16 PM   #1
I have gas!
Clutchcargo's Avatar
tacking wire in stud wall
Do you need to tack nm traveling horizontal through a stud wall. Does the 4'6" between tacks apply here?
Also does it make any difference where that wire is in the wall... below outlets, above outlets, does it matter?
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 10-19-2011, 08:30 PM   #2
Licensed electrician
Through drilled holes counts as secured.
Above or below does not matter. Leave enough space above or below the box for the staple. Above the box you do not need to bend over so far to pull the wire.
Old 10-19-2011, 08:39 PM   #3
I have gas!
Good point, I'm at that age too.
Old 10-19-2011, 08:42 PM   #4
liscenced electrician
if a wire goes through a drilled hole, it is considered secured. This does not apply next to box. Where it enters a box it still needs to be stapled within 8 inches
sorry, i wrote my post out, but then got distracted. I see its already been answered
jimmy21 is offline   Reply With Quote
Trouble with staggered wall rightit Building & Construction 2 03-09-2011 07:23 PM
Question about neutral wire through wall switch guitarmonster Electrical 33 08-08-2010 10:51 PM
Remove 20 inch Stud on A Bearing Wall triduong Building & Construction 7 08-03-2010 06:14 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
How to butt wood stud wall to steel stud wall? Yorkergizer Building & Construction 3 12-01-2007 01:28 AM
