T5 Shop Light Wiring Orange Plug? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-06-2011, 09:35 AM   #16
Originally Posted by frenchelectrican View Post
That confirm my question and other electrician's question as well so you will have to hook that grey conductor on to get the other set of lamps on { gris to black }
That is two level ballast set up I do run into once a while but not very often.
Merci,
Marc
So to be clear, I would wire black to black, white to white, and pigtail black to grey for all the bulbs to be on at once.
If I wanted two switches to run half at a time I would wire one switch black to black and white to white. The other switch would be black to grey and white pigtailed to white.
cre10 is offline   Reply With Quote
Old 10-06-2011, 09:55 AM   #17
Electrical Contractor
jbfan's Avatar
Rewards Points: 140
That is correct.
If this is what you want to do, yrun a peice of 3 wire cable from the switches.
Black to black is one switch.
Red to gray/red would be another switch, and white is neutral.
Don't forget the ground.
jbfan is online now   Reply With Quote
The Following User Says Thank You to jbfan For This Useful Post:
cre10 (10-06-2011)
Old 10-06-2011, 09:59 AM   #18
Originally Posted by jbfan View Post
That is correct.
I think I will just wire them to all come on at once. I don't imagine ever needing just two bulbs versus 4.
Old 10-06-2011, 10:02 AM   #19
jbfan's Avatar
Rewards Points: 140
Then just wire the black and grey/red to the incoming hot wire.
Old 10-06-2011, 03:08 PM   #20
Just curious, why does it say "neutral or (any hot)". In what case would you wire a neutral into it? Neutral and hot are opposites.
Old 10-06-2011, 04:05 PM   #21
jbfan's Avatar
Rewards Points: 140
I'm not really sure!
Old 10-06-2011, 04:19 PM   #22
I=E/R
a7ecorsair's Avatar
Well, hot and hot are opposite too
a7ecorsair is offline   Reply With Quote
help wiring exhaust fan w 2 lights AND a separate shower light into a 4 switch Taran7 Electrical 2 09-18-2014 07:07 PM
Wiring Lights To A Plug TssCman123 Electrical 60 07-28-2012 05:00 AM
wiring a light fixture to an existing plug receptacle box? San Mike Electrical 7 09-19-2011 01:58 PM
Question with wiring up a flood light. SuperAkuma Electrical 6 09-20-2008 11:58 AM
converting hanging light fixture to plug dukeswalker Electrical 2 09-18-2006 10:03 PM
