T12 Ballast To T8 - Electrical - DIY Chatroom Home Improvement Forum
Old 07-09-2011, 04:51 PM   #1
T12 ballast to T8
I am inexperienced with dealing with electricity and wiring. I have wired the old T12 ballasts (8') in and they have worked fine. I recently purchased new ballasts for 4 lamps where the ballast has burnt out. I have heard that the T12 ballast can be converted to the T8 ballast that I now have, i just dont know how. The old ballast had one white, black, blue, and red wire. The new ballast has two blue, one white, black, and red. How should the new ballast be wired in? Sorry if this sounds like a dumb question, I just dont want to short anything out or burn up the new ballast too fast. Thanks.
c.bustle is offline   Reply With Quote
Old 07-09-2011, 04:59 PM   #2
Licensed electrician
Rewards Points: 1,880
There should be a wiring diagram right in the ballast.
Old 07-09-2011, 05:56 PM   #3
yeah, it has a diagram, but im still not exactly sure which wire goes to which...
ive had other people tell me different things, such as one guy just told me to connect one blue to one blue and the other blue to the red and cap the loose red thats coming out of the ballast, but even with the experience that I have, that doesnt sound right. I was just wondering if there was a way to connect the two bulb posts so that I could connect both blue wires from the ballast to the one blue wire to the bulb post...?
Old 07-09-2011, 07:52 PM   #4
Semi-Pro Electro-Geek
Rewards Points: 2,990
Tons of google results for this, including lots of discussion forum threads like this one:
http://www.chameleonforums.com/diy-t...-change-31490/
mpoulton is offline   Reply With Quote
Old 07-10-2011, 07:10 AM   #5
Electrician
SD515's Avatar
Rewards Points: 504
Compare the diagram of the old ballast to the diagram of the new ballast. Each will show what the wires are to meant to do. Sometimes you have to connect one of the new wires to 2 of the old wires. Sometimes not.
Kyle
Old 07-10-2011, 10:33 AM   #6
Thanks all. got them wired up
Replacing Ballast rjgorman Electrical 10 06-30-2011 05:20 AM
wiring a ballast from t12 to t8 family Electrical 3 05-17-2011 08:57 AM
Circline bulb and ballast anton2148 Electrical 6 07-06-2010 03:16 PM
No ballast in 48 inch fluorescent fixture. Timster Electrical 16 06-10-2010 04:02 AM
please help w/ selection of bad ballast Mack V Electrical 8 10-17-2006 09:54 AM
