T Stat With 2 Wires On 240? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-20-2009, 06:39 PM   #1
T stat with 2 wires on 240?
I recently installed a 240V hydronic electric baseboard heater in a bathroom.
The thermostat that I purchased to control the heater was sold with the heater as a kit from a company in SC. The T stat has a triac in it to vary the current (or is it voltage?) supply to the heater, based on rise needed, room temp......
This T stat is single pole. I'm now hearing that single pole on 240 is against code in the US. Does the triac change that or should this product not be sold here?
Wiring is as follows:
1 side of supply to T stat
2nd side of supply to heater element
2nd side of heater element ( temp limit switch) to other side of T stat
Am I safe?
Heater has a chassis ground that is connected to supply ground
Thanks.
OffRoadAudio is offline   Reply With Quote
Old 10-20-2009, 07:19 PM   #2
A switch must turn both legs off but your thermostat is considered control wiring and may switch just one leg.
220/221 is offline   Reply With Quote
Old 10-20-2009, 07:30 PM   #3
Great - thanks for the clarification.
Old 10-20-2009, 09:33 PM   #4
Electrical Contractor
kbsparky's Avatar
Single pole line voltage thermostats do not provide "disconnecting means" for connected heating units. Because of this, they do not have an "off" position.
-KB
Old 10-20-2009, 10:04 PM   #5
Rewards Points: 1,536
While they make two pole full line voltage/current controlling thermostats for electric heaters, it is actually rare that both poles open or close automatically at exactly the same time. I have even used some whose calibration is off far enough that turning the dial manually also has the poles opening and closing at noticeably different dial positions.
In normal operation with both leads to one heater connected, this usually means that one of the contacts does all of the switching under load. If instead the double pole thermostat is used to control one lead respectively of two heaters, usually the temperature will fall further enough that the second heater will be switched off (and on again) before the first is switched back on.
Old 10-21-2009, 06:15 AM   #6
kbsparky's Avatar
That is correct. The only way to ensure both poles are open with a double pole thermostat is to turn it "off"
-KB
Old 12-13-2011, 06:52 PM   #7
so it's ok to use single pole t stat on 240V?
Kris. is offline   Reply With Quote
Switch Junction box has 3 sets of 3 wires. Can't get dimmer to work knockout Electrical 14 01-10-2015 09:08 AM
Unfused connectors MELTED House wires WHAT TO DO??? jamiedolan Electrical 63 02-12-2009 06:01 PM
LUX digital stat Trane XE80 intermittant problem rossl56 HVAC 6 12-26-2008 05:53 AM
replacing outlet with 3 white/3 black wires gpet573 Electrical 4 06-03-2008 02:55 PM
Two black wires with one white! Please help! ibs325 Electrical 15 11-18-2007 09:38 PM
