Sylvania Panel, Gould QP Breakers - Electrical - DIY Chatroom Home Improvement Forum
Old 09-16-2012, 07:22 AM   #1
Rewards Points: 77
Sylvania panel, Gould QP Breakers
Hello again Gurus,
My house was built in 1983. We purchased about 2 years ago, 1 previous owner that had the house built. My panel is a 200A service. Main panel is labeled as Sylvania. However, all the breakers are Gould type QP. I know that they all (ITE, Sylvania, Challenger, Westinghouse) got bought out by Siemens. My 15A GFI breaker for bathroom and outside receptacles is cracked right down the middle on top of breaker and I'd like to replace. It's a good size crack. I removed and found no burning and couldn't smell any burntness on the breaker or panel for that matter. However, I'd like to replace. Can I just use a Siemens (aka Murray) 15A Type QP GFI to replace? I believe the make/model is QF115P.
Thanks,
~S
Skelleyman is offline   Reply With Quote
Old 09-16-2012, 06:00 PM   #2
Electrical Contractor
kbsparky's Avatar
Originally Posted by Skelleyman View Post
... I know that they all (ITE, Sylvania, Challenger, Westinghouse) got bought out by Siemens....
From the Mike Holt site:
The Cutler-Hammer BR series is the direct replacement for this panel. If you look at a BR120 breaker it will also have a C120 part number on it. Sylvania became Challenger then Westinghouse purchased the Challenger line but didnít merge the Challenger and Bryant lines together. When Cutler-Hammer purchased the Westinghouse distribution line the merged the two lines together but use the Bryant catalog numbers. The old Sylvania/Challanger numbers are still printed on the breakers so they can be used in older panels.
-KB
Old 09-16-2012, 08:41 PM   #3
Rewards Points: 77
Thanks KB. So I could use Eaton BR too, correct?
Old 09-16-2012, 08:43 PM   #4
Rewards Points: 77
And why the Gould QP breakers in there?
Old 09-16-2012, 09:00 PM   #5
kbsparky's Avatar
Yes, Cutler-Hammer type BR.
-KB
Main Service Panel to 2 breaker panels - I can imagine you all rolling your eyes kalus Electrical 22 03-23-2012 02:09 AM
Twin Breakers 15A single pole Bolt-on type for Sylvania Panel Antoine S Electrical 14 04-17-2011 08:10 PM
All breakers in panel trip? 3phase Electrical 16 02-11-2011 10:57 PM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 08:43 PM
Adding a second Electric sub panel TW Lucas Electrical 9 10-05-2008 02:37 AM
