Sylvania Breakers - Electrical - DIY Chatroom Home Improvement Forum
Old 10-27-2012, 01:32 PM   #1
Rewards Points: 340
Sylvania breakers
heh KB Sparky
I bought a house with Sylvania's and the 220 circuits are not clipped together
Did they use and external clip or have a rod thru the hole in the breaker handle?
are there in comparable pins that will work on these breakers to clip them together
kt82 is offline   Reply With Quote
Old 10-27-2012, 02:07 PM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,938
You have 240V circuits that use two single-pole breakers instead of a double pole? The only solution for that is to get double pole breakers. Handle ties are not a substitute, since 240V loads require a breaker with an internal common-trip. Handle ties don't do that.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 10-27-2012, 03:47 PM   #3
Rewards Points: 340
Now I know . thanks for the heads up
Old 10-27-2012, 03:53 PM   #4
Rewards Points: 340
No , I checked they are double pole ,but 2 of then don't have the poles clipped together and 3 of them have a rod thru the poles
Old 10-27-2012, 04:46 PM   #5
Oso954's Avatar
Rewards Points: 1,116
Just out of curiosity, do your breakers look like this ?
Its a Zinsco breaker, but a lot of people have made them including Sylvania.
In my area, the big boxes and hardware stores carry the tandems, but not the common trips. I have to drive about 20 miles to get them from an electrical supply house. So, I have run into a lot of them with nails thru the handles.
It' not right, but a lot of people have done that.
Oso954 is online now   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
kt82 (10-27-2012)
Old 10-27-2012, 05:23 PM   #6
Rewards Points: 340
I did cut an 8pd nail down to fit in the hole when I first noticed them missing, but it didn't look kosher
.looks like when it trips it will take both rockers out though.
I have a box full of Zinsco's
The Following User Says Thank You to kt82 For This Useful Post:
Oso954 (10-27-2012)
Old 10-27-2012, 08:57 PM   #7
Rewards Points: 27
Zinsco was bought by GTE in 1973 which they later renamed Sylvania, as they later sold off their electrical equipment div. that line was discontinued they were then renamed Challenger, who continued to make replacement breakers, they were bought & sold a couple more times & no longer exist but a company called UBI makes ChiCom sourced replacements*, Zinsco / Sylvania is one of the two most reviled names in electrical equipment, Federal Pacific Electric, FPE is the other.
* I would rather use old Zinsco then use ChiCom breakers, but that is just my opinion, the best thing to do is get rid of them as they have been obsolete for somewhere around 30 years give or take, and were used because they were cheap, one reason that you see them in a lot of tract homes & multi-family buildings, depending on what part of the US one is in.
Norcal is offline   Reply With Quote
Old 10-28-2012, 05:51 AM   #8
Code05's Avatar
Rewards Points: 1,104
Not all 240V loads require a two pole common trip breaker.
Read 210.4(C) 2008 or 2011.
Code05 is offline   Reply With Quote
Old 10-28-2012, 07:42 AM   #9
Rewards Points: 340
If you elect to use multi-wire branch circuits (be sure to see the Code definition), then you need to meet the requirements of 210.4(B) which, at a minimum, requires the use of handle ties on SP breakers employed with MWBC.is a 220 application a MWBC?
Just wondering about DP breakers .if one side ''trips'' on double pole with out the handle clip ,does that close the circuit on both sides automaticlly?
Never realized yall had so much verbage to wade thru to wire a house .
It looks like the NEC is just trying to cover thei behind with multiple ways to interpret what they require
Old 10-28-2012, 07:48 AM   #10
Rewards Points: 340
Branch Circuit, Multiwire. A branch circuit that consists of two or more ungrounded conductors that have a voltage between them, and a grounded conductor that has equal voltage between it and each ungrounded conductor of the circuit and that is connected to the neutral or grounded conductor of the system.
So my 220 oven circuit ,that has a neutral and a ground would be a MWBC?
Old 10-28-2012, 07:53 AM   #11
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
No, it would not be considered a MWBC, but would require a 2-pole breaker.
What do your breakers look like? If they are typical 1" style breakers Cutler Hammer BR series would be an acceptable replacement if a handle tie cannot be found. They are pretty cheap.
The Following User Says Thank You to Speedy Petey For This Useful Post:
kt82 (10-28-2012)
Old 10-28-2012, 08:03 AM   #12
Rewards Points: 340
Is it wrong to reply to your own thread?
but I was just thinking in my 40 years of remodeling I do not remember ever seeing a DP breaker trip
Old 10-28-2012, 08:05 AM   #13
Rewards Points: 340
thank you. I will get them replaced with the BR's.
When the electrician comes out it is cheaper if you can spec out everything that needs to be done(only 1 trip charge)
Sylvania panel, Gould QP Breakers Skelleyman Electrical 4 09-16-2012 09:00 PM
GE Panel - Breakers - Tandem or Slim? TBrown1 Electrical 12 06-05-2012 07:42 PM
breakers compatible with panel--HD says... Daneel Electrical 6 06-10-2011 06:31 PM
Twin Breakers 15A single pole Bolt-on type for Sylvania Panel Antoine S Electrical 14 04-17-2011 08:10 PM
Can I get AFCI breakers for my panel? BlueBSH Electrical 21 08-04-2010 07:07 AM
