Switchloop On Older Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 06-14-2013, 03:08 PM   #1
Rewards Points: 156
switchloop on older wiring
In the late 70 s early 80s on light circuits did they do the switchloop technique on single pole switches (white an black on switch)..I removed both on a few light switches all on light circuit and found each with neutral and hot on switches.
Does have copper to green screw also.
hidden 1 is offline   Reply With Quote
Old 06-14-2013, 03:16 PM   #2
Rewards Points: 320
The white is not a neutral on the switch the black and white are both hot. The white wire should be recoded with black tape to signify it as a hot wire. It wasn't used only in the 70's/80's, it is/was done depending on whether the power comes into the switch box or the light box first.
teamo is offline   Reply With Quote
Old 06-14-2013, 08:10 PM   #3
Electrical Enthusiast
Rewards Points: 504
It was certainly more common back in the 70s than it is now. Like teamo said, it usually just depends on whether the power feed is sent to the light fixture or switch box first.
One "problem" with switch loops is that no neutral is present at the switch. The white wire is used to bring power to the switch instead of serving as the Neutral. Many modern timer/occupancy switches require a neutral, and can't be used with this setup. I believe modern code (2008?) requires a neutral wire present at every light switch for this reason. This does not matter if the house was built before this code cycle; it is grandfathered in in that case.
Our house was built in 1976 and nearly every light is on a switch loop.
Kyle_in_rure is offline   Reply With Quote
Old 06-15-2013, 01:03 AM   #4
Rewards Points: 506
Not in '08, Kyle. I think it's in "11 or upcomng in '14.
This is important. Many states and communities are on older versions of the NEC, and not everyone is required to adhere to this amendment. It's the same with AFCIs; in my County, they have specifically NOT REQUIRED them until an AFCI receptacle is readily available.
Installation is the Reverse of Removal.
The Following User Says Thank You to sirsparksalot For This Useful Post:
Kyle_in_rure (06-15-2013)
Old 06-15-2013, 01:43 AM   #5
Rewards Points: 504
Thanks for the clarification; forgot to mention that.
I personally don't have a problem with switch loops. Sometimes they are more convenient if you have an existing circuit already.
I believe AFCIs are now required in my area.
Old wiring to new wiring Acworld34 Electrical 3 07-11-2011 11:00 AM
Concrobium and knob and tube wiring WillK Electrical 13 02-28-2011 01:17 PM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 03:40 PM
Wiring in older house ? Piney Electrical 11 03-11-2007 12:56 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
