Switching Problem... - Electrical - DIY Chatroom Home Improvement Forum
Old 07-10-2012, 07:16 PM   #1
Switching problem...
I have a problem with my switching. Testing between neutral and phase at one switch, I get 230V, but at the 2nd switch I get nothing. It is definitely the same feed, I've traced it back and everything. What could be the problem? Would it be something to do with the neutrals? I'm lost.
Please help, I can't get my lights working!
Elsam is offline   Reply With Quote
Old 07-10-2012, 10:13 PM   #2
Rewards Points: 83
Take pics. Also, check voltage to ground as well and post those. What are the colors of the wires?
You should see 120V from Hot to Neutral and ground.
Protocol. is offline   Reply With Quote
Old 07-10-2012, 10:30 PM   #3
joed's Avatar
Rewards Points: 13,762
Without know how you ran cables and connected the wires there is no way I can know what might be wrong.
Old 07-10-2012, 10:34 PM   #4
Electrical Contractor
kbsparky's Avatar
Bad or loose neutral. On a multi-wire circuit, or the entire house.
Are all the lights in the house not working, or just this one (2) circuit(s)?
-KB
Old 07-11-2012, 01:28 PM   #5
I'm in NZ, s it should be 230V not 120V...
Anyway, found the problem, there was a broken neutral in the roof. Cheers guys
Old 07-11-2012, 04:44 PM   #6
Master Electrician
Wow guys and gals. You should have known he was in new Zealand from your psychic powers :D or it could just be I'm on my phone and can't see the location.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 07-11-2012, 05:15 PM   #7
Everyone should also be ashamed of themselves for not even mentioning looking for a broken neutral on the roof. That should be your first suggestion... Every time... gsssh
CopperClad is offline   Reply With Quote
2 TVs fried: Electrical vs. Comcast Coax Cable Problem LynOprinka Electrical 17 07-16-2012 08:01 PM
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 11:53 AM
Don't understand this breaker tripping problem majesticjess Electrical 10 03-05-2010 06:42 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
