#1 |
Switching outlets in an older house...
Hey everyone. I need to switch out some old, two-pronged outlets in my grandma's house. I'd like to install new three-pronged ones.
I pulled one of the outlets from the wall to take a look at it, and I saw two white wires connected to one side of the outlet, a red wire connected to the other side, and two black wires twisted together with a wire nut shoved behind the outlet. I expected to see a ground wire, but wasn't sure which was which. This particular outlet is controlled by a switch, so I figured I should check out another outlet that's not switch-controlled to see if it was any different. The next outlet I pulled had two white wires connected to one side and two black wires connected to the other -- no ground. I looked into the box itself, hoping to find a ground wire folded up somewhere in there, but there was none. The other non-switch controlled outlets look the same. The house was built in 1955 and I'm sure the outlets are the originals -- any ideas on how to convert them? Or if I should/can? Thanks for any help you can provide. |
#2 |
DIY
Depending how old the wiring is, if you find that the house uses metal electrical boxes, and shielded wire, that may be the ground.
In that type of wiring, the ground is carried from the breaker box all the way through the wires and to the electrical box itself. In this setup there is typically only 2 wires, and the shielded metal is the ground. You may be able to get a copper wire and hook it from the metal electrical box to the ground screw on the new 3-pronged outlet, but I'm not sure if that will work in your setup. Someone else may be able to help chime in on the wiring scenario's you are up against. |
| The Following User Says Thank You to RocketManZ For This Useful Post: | abbyqueue (10-24-2011) |
#3 |
If there is no ground, you can install a new two prong outlet, or install a GFCI and apply the sticker “No equipment ground" on the front. These come with GFCI's.
Note these will not allow surge protector power strips to function properly as would rewiring with grounded wiring and a 3 prong outlet. Best would be to have an electrician rewire the outlets you want to be 3 prong... |
| The Following User Says Thank You to Billy_Bob For This Useful Post: | abbyqueue (10-24-2011) |
#4 | |
Average Joe/ex-Navy IC3
Switching outlets in an older house...Quote:
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you? |
#5 |
abbyqueue,
1- Does your town/ state require a permit for the work you are considering? (this will vary from one area to another.) 2- Does your town/state require a license to perform the necessary work? (this will vary from one area to another.) 3- If no license is required, do YOU have the necessary skills to do the job safely? 4- WHY replace the switched? is it because all the appliances/electronics have a 3 prong plug, or some other reason?
That's just my opinion. But it's free, so take it for what it's worth to you. |
| The Following User Says Thank You to 1910NE For This Useful Post: | abbyqueue (10-24-2011) |
#6 | |
Pre 1960 homes used two wire outlets to save money on the most expensive part - a third copper wire inside electric cable. Made little sense to run that third wire and then not use it. Last edited by westom; 10-24-2011 at 10:08 AM. |
#7 |
Abbyqueue, installing gfci is not going to create grounded outlets. Hooking up three prong outlets, is not going to automatically make them grounded properly. Only way to do this safely and be assured that you have grounded outlets, is to pull all new romex, unless your area requires bx or conduit, then it is a lot more work.
If you feel that the scope of work is beyond your abilities, hiring an electrician is the proper way. Using power strips is the improper way. Same with extension cords.
#8 |
I understand that installing GFCIs or three-pronged outlets doesn't make them grounded. I don't mind them not being grounded if there's truly no ground wire already being run to the receptacles. I'm just asking what my options are, and to my understanding, I've listed them above.
#9 |
Your options are either: Have an electrician update the current wiring and older panel if fuse panel; add outlets where there are not any at this time. Those are the only two options to bring it up to current codes.
#10 | |
liscenced electrician
#11 |
Yes it is legal to do so, but does not make it a grounded outlet.
| Display Modes | |
| Supplemental Outlets in 1950's House | Perry401 | Electrical | 2 | 05-01-2011 09:49 PM |
| Stud spacing above a fireplace in an older house? What's going on? | CoconutPete | General Discussion | 13 | 01-28-2011 06:42 PM |
| Lost Power to all of my outlets throughout house | allie74 | Electrical | 5 | 04-15-2010 02:32 PM |
| vapor barier for older house | larry proctor | Building & Construction | 5 | 11-07-2007 02:39 PM |
| Wiring in older house ? | Piney | Electrical | 11 | 03-11-2007 12:56 PM |
