-   -   switching low voltage lighting (http://www.diychatroom.com/f18/switching-low-voltage-lighting-69939/)
handifoot 04-26-2010 11:38 PM
I am planning to set up some 12V landscape lighting and I would like the convince of using a standard light switch on the side of my shed to control it.
So, can I plug the transformer into the switched half of a split switched receptacle for on and off? Also, this branch is protected by a gfci further upstream. Would that interfere with this idea? Thank you.
oberkc 04-27-2010 09:08 AM
I believe this to be a great idea. I can think of no reason why it would not work.
