Switching A Light And Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 01-29-2012, 12:34 AM   #1
Experienced
Naz1298's Avatar
Switching a light and fan
I have a room with one switch to the light/fan. If I wanted to put two switches to control the light and fan separately what would be the easiest way to go about it.
Naz1298 is offline   Reply With Quote
Old 01-29-2012, 12:42 AM   #2
Julius793's Avatar
Home depot sell a nice kit for this so you don't have to change the wiring. It's kinda like a remote except it's built in. I will look for a link to it.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-29-2012, 12:42 AM   #3
you would need another wire from the switchbox to the fan/light box. they also sell fans with remotes so you dont have to rewire
Old 01-29-2012, 12:45 AM   #4
Rewards Points: 13,748
Without the remote your going to have to run a new three conductor wire down and remove what you have and add a double switch.
Old 01-29-2012, 09:07 AM   #5
Experienced
Naz1298's Avatar
So without the remote fan it's just running a new wire from the fan to the new double switch? I won't have to run a new power from the fuse box in the garage right?
Old 01-29-2012, 09:19 AM   #6
Julius793's Avatar
That's correct you can use the same power as the switch
Old 01-29-2012, 11:30 AM   #7
Experienced
Naz1298's Avatar
Kewl. That'll make it much easier. Thanks for the help everyone.
