Hey all,
So I had these two ugly fluorescent fixtures. I removed both and tried installing halogen track lighting. Obviously it did not work and it shorted out.
http://www.homedepot.com/Lighting-Fa...&storeId=10051
So the switch turns on both, but I only need to hook up one fixture. I tried hooking it up to where the first fixture used to be, so it has two positives, two negatives and one ground. I essentially did nothing with the second one, which only has one positive, one negative and one ground.
What I am doing wrong? Do I need to eliminate the circuit going to the where the second fixture used to be? Or maybe hook up the new fixture to it instead?
Thanks.
