Switching To CFL (Compact Fluorescent Light) - Electrical - DIY Chatroom Home Improvement Forum
Old 06-29-2007, 11:45 AM   #1
ICF built home
Question
Switching to CFL (Compact Fluorescent light)
I have a ceiling fixture that is rated for 3 60watt bulbs. I am considering changing the bulbs over to CFL's.
Since the actual wattage used by CFL bulbs is significantly less than a traditional bulb is can upgrade the light output when I switch bulbs?
By this I mean.... Can I pull out the traditional 60 watt bulb and stick in a CFL that is rated to provide the equilivant of 100 watts of light yet in reality it is only really consuming 23 watts to provide that light?
Common sense tells me that this should be perfectly fine since I am not asking the fixture to provide more wattage than it is ratted for.
Any comments?
Dragon is offline   Reply With Quote
Old 06-29-2007, 12:58 PM   #2
this is perfectly fine I think too...
KUIPORNG is offline   Reply With Quote
Old 06-29-2007, 05:49 PM   #3
Master Electrician
JohnJ0906's Avatar
The watt rating of the fixture is really how much HEAT the fixture can handle. I don't know how the heat ratings between incandescent and CFLs match up. The CFL bulb is cool, but the ballast part can get warm. Might be something to look into.
A little off subject, but I want to mention that the fixture ratings are NO JOKE! If it says 75 watt incandescent, DO NOT put a larger incandescent bulb in! You can cause a fire! I've seen some serious damage done due to ignoring the ratings!
John from Baltimore
One Day at a Time
"Experience is what you get when you were expecting something else"
"The bitterness of low quality lingers long after the sweetness of low cost is forgotten"
JohnJ0906 is offline   Reply With Quote
Old 06-30-2007, 12:08 PM   #4
Eibwen
Rather than increasing the wattage on the CFL, try getting the "bright" or "daylight" version of the lower wattage CFL bulb versus the "soft white" that most people get.
I did some of my lights last fall and started out with the soft whites but went up to brights becasue the soft whites were just too dim.
Sammy is offline   Reply With Quote
Compact Fluorescent Lighting? kcrossley2 Electrical 2 07-23-2007 11:18 PM
Fluorescent light ballast billinak Electrical 5 03-02-2007 06:41 PM
Hot Light Outlets Materials Guru Electrical 5 07-31-2006 08:11 PM
Switching from light socket to plug - stupid question CGofMP Electrical 5 03-25-2005 10:48 PM
Noisy, humming fluorescent light Unregistered Electrical 1 11-14-2004 04:28 AM
