Switching From 15 Amp Range Hood To 20 Amp Dedicated Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 09-04-2010, 07:52 AM   #1
Switching from 15 amp range hood to 20 amp dedicated circuit
We're switching from a 15 amp range hood that is on a shared circuit with other lights to a 20 amp dedicated OTR circuit. My question is what do I do with the 15 amp line? Do I just cut the end back to the sheathing, cap the end and run it into the new box I plan on putting in for the new circuit or can I do something else?
Thanks in advance.
BFDvollie is offline   Reply With Quote
Old 09-04-2010, 08:00 AM   #2
Rewards Points: 869
if the 15 amp (14 gauge?) branch circuit services additional loads as you said, it must remain, whether or not it can stay in the same physical location is up to you. the new 20 amp circuit will need 12 gauge wire and 20 amp breaker. i don't know what "otr" represents.
TimPa is offline   Reply With Quote
Old 09-04-2010, 08:03 AM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
The easiest thing is going to be to run it into the new box and cap it off. This way you do not have to trace it to find the feed and kill it there.
OTR = Over the range
Speedy Petey is online now   Reply With Quote
range hood vent vinman Roofing/Siding 6 05-07-2012 01:23 PM
Range hood installation problem Lucas718 Appliances 4 08-16-2010 01:28 PM
New Range Hood - robbing combustible air??? drtbk4ever HVAC 2 05-26-2009 10:24 AM
Insulating a range hood? snapshotmd HVAC 3 01-13-2009 08:55 PM
Range Hood Duct Size BOUTYM Appliances 2 12-20-2008 06:34 AM
