Switches And Outlets - Electrical - DIY Chatroom Home Improvement Forum
Old 03-15-2011, 11:16 PM   #1
switches and outlets
I was replacing 2 separate outlets where the top plugs are controlled by a single switch. Once I followed the wiring correctly, the switch doesn't control anything and all 4 plugs are hot all the time. I want it so the 2 top plugs are controlled by the switch and the bottoms are always hot.
Found earlier post that I have to break off a tab--will look for that tomorrow and fix.
2nd problem: I have 2 switches on opposite walls that control 1 light. In that configuration, I have a single switch that controls an outside light. ALL the wires on the outside wall are black!!! Stupidly, I didn't pay attention when replacing the single switch for outside light. I now have an extra wire!!! When I hook it to the single switch, none of the light switches work. When I tried to hook it to the 2 switches connectors, it screws up my switch controlling the other lights. I have read my home improvement book, looked up diagrams online and nothing is making sense. My question is this---did I buy the wrong switch for my single switch that is housed with one of the 2 switch controls. The one I bought is much thinner than the other one it is housed with.
kitty5568 is offline   Reply With Quote
Old 03-15-2011, 11:31 PM   #2
Scared Electrician
Saturday Cowboy's Avatar
you need to break the tap. On the hot side of the receptacle there is a little tab between the 2 screws, removal of this tab will allow the outlets to be controlled indivually
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
The Following User Says Thank You to Saturday Cowboy For This Useful Post:
kitty5568 (03-15-2011)
Replaced some switches and outlets, now some lights don't work DWooderson Electrical 3 02-02-2010 12:06 PM
Replaced outlets, now wall switches don't work? PittsburghPaul Electrical 3 08-09-2009 05:50 PM
Outlets Work - Switches Do Not? Quick Electrical 6 08-13-2008 04:10 PM
replacing old outlets and switches Nailpounder Electrical 7 04-28-2008 09:36 AM
15A or 20A switches & outlets MIKEGOUGH1 Electrical 1 03-14-2007 07:04 PM
