Switches Out Of Sync - Electrical - DIY Chatroom Home Improvement Forum
Old 06-08-2010, 08:39 PM   #1
switches out of sync
How do I get a light that is controlled but three switches (one at the door entry, one at each side of the headboard to the bed) in sync????Never can get all three switches to work in sync.... this drives me nuts!!!! 2 are always wrong and one right... what do I do????
Linda Shufeldt is offline   Reply With Quote
Old 06-08-2010, 08:50 PM   #2
dSilanskas's Avatar
wires are crossed.
dSilanskas is offline   Reply With Quote
Old 06-08-2010, 08:51 PM   #3
dSilanskas's Avatar
Open up the switches are take pictures or tell us what you have for wires.
Old 06-08-2010, 08:54 PM   #4
I usually take out one switch & flip it over
*jynx*
Old 06-08-2010, 08:54 PM   #5
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
turn the odd switch upside down
If what you mean is you have 2 3 way switches and 1 4 way switch, you can always end up with an odd switch depending on what order you turned the lights on and off using any given switch. If you are this anal about the switches, I suggest you get push button switches
Old 06-08-2010, 08:59 PM   #6
dSilanskas's Avatar
I think they are saying that the travelers are reversed on one of the switches so they are not working right. But I could be mistaken
Old 06-08-2010, 09:24 PM   #7
Sparkaholic
Rewards Points: 150
Send a message via Yahoo to sparks1up
Focus your energy on something more deserving of your attention! There is nothing wrong with the switches, they will never "sync up" no matter what you do! But hey ...guess what? They are working exactly as they should! You have the ability to turn on or off the light no matter which entrance to the area you use and if you look you will see that none ...not a one of those switches says ON or OFF in any position. That's because they can be ON or OFF in any position...pretty versatile wouldn't you say?
Answers based on the mood I am in when you ask!
sparks1up is offline   Reply With Quote
Old 06-08-2010, 09:24 PM   #8
Licensed electrician
Rewards Points: 1,054
I agree with Nap, 2 3ws and a 4w. One of the switches is up when the lights are off. or down when on.
If I need to turn those lights on I just change the switch to the other position.
Old 06-08-2010, 09:36 PM   #9
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
I truly hope you are not referring to the position of the switches like the other are suggesting.
There is NO "right" or "wrong" position when it comes to 3 & 4 way switches.
Old 06-08-2010, 10:25 PM   #10
Learning by Doing
Leah Frances's Avatar
Here's how they stay in sync:
Let's imagine lights are out and all switches are down.
- OP enters room and switches light on at door: lights on and now two down = 'off', one up = 'on'.
- OP turns off light at one side of head board by switching it up: now lights off with two switches in the up or 'on' position and one switch in the down or 'off' position.
- OP gets up in the AM and turns on the lights by switching the light by the bed into the down or 'off' position. Again lights are on with two switches in the 'off' position.
- OP leaves the room turning the lights off by switching the switch by the door into the off position . Lights off and all switches are 'off'
Or, if you skimmed this because it's wordy and absurd - there's a reason they don't print on and off on three way switches - it's cause they're toggle switches NOT on/off switches.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 06-09-2010, 09:29 AM   #11
Rewards Points: 1,418
This is one of those unsolvable math problems discussed at length in Victorian themed high ceilinged libraries over tea.
Given a 4 way switch setup (3 switches) exactly one of the following will be true:
1. The light will be off when all three switches are down and on when all three switches are up,
2. The light will be on when all three switches are down and off when all three switches are up.
If you physically open up one switch box and turn the switch upside down, you will convert from #1 to #2 or you will convert from #2 to #1.
In addition, if you label the switches A, B, and C, then if for a given setting of A, a given setting of B and a given setting of C the light is on, then the light will always be on for that group of (up/down) settings regardless of what order you flipped the switches to get to that group of settings. For three switches there are eight groups of settings; the light will be on for four of those groups of settings. I will leave it as an exercise to write down those settings all on one sheet of paper in tabular form.
Hint: Imagine that all of the switches are down and the light is off. By definition, in a 3-way or 4-way setup, flipping any one switch turns the light (on/off). Flip one switch up. The light goes on. Flip another switch up. The light goes off. Flip the third switch up. The light goes on.
OT: Yet another unsolvable problem for you math Ph.D's. The 7 bridges of Ko:nigsberg (Koenigsberg).
Question about wiring and voltage with switches and lights rswurth Electrical 17 06-21-2010 12:12 AM
Question about switches on a 20 amp circuit Abs777 Electrical 6 04-28-2010 11:09 AM
2x Three Way Light Switch - switches out of sync zurgdawg Electrical 9 12-18-2009 08:20 AM
Replacing switches turning into nightmare. RyanD Electrical 19 05-26-2009 07:19 PM
Need help replacing switches in four-way circuit magnolia Electrical 3 05-09-2008 10:40 PM
