Switches On Opposite Side Of Wall - Electrical - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By joed
Old 10-20-2016, 06:54 PM   #1
Rewards Points: 174
Switches on opposite side of wall
My intent is to wire two switches in a space that's split in half by a wall; I'll use a 2gang box on one side of that wall for some lights in that section. Then I'll use a single gang box on the other side offset by ~3inches or so as to not butt up against the other box BUT there's wires running down the stud I was planning on using. Can I run the wires over the outside of the junction box and let them continue downward to their receptacle?
http://i.stack.imgur.com/7QhfR.jpg
http://i.stack.imgur.com/xWvVL.jpg
Doesn't seem right but not sure how else to work around this??
tb582 is offline   Reply With Quote
Old 10-20-2016, 07:53 PM   #2
Usually Confused
lenaitch's Avatar
Rewards Points: 824
Re: Switches on opposite side of wall
I'm not aware of a rule that prevents running outside of the box (but a pro might) BUT you are supposed to secure the cable within I think 1' of the box (like the cable running down from the 2-gang) so that creates a problem unless there is an exemption. Depending on how you plan on finishing that wall there is a general rule that cable must be protected from physical damage.
lenaitch is offline   Reply With Quote
Old 10-20-2016, 08:09 PM   #3
Rewards Points: 174
Exactly - there's got to be others that run into the same problem how is it solved? I don't suppose it's OK to tack the wires onto the stud and then put the box over the wires?
Old 10-20-2016, 08:19 PM   #4
hkstroud's Avatar
Rewards Points: 1,706
May I ask why your studs are oriented in that manner?
Since the single gang box will only contain a switch can you use a shallow box such as shown below.
Also why does the boxes have to be on the same side of the stud.
I believe the NEC rule is that the cable must be secured with in 8" of the box. However, I would not be too concerned about that. It is not flapping around in mid air.
hkstroud is offline   Reply With Quote
Old 10-20-2016, 08:24 PM   #5
Rewards Points: 46
Around here, it's 6" IIRC. I'm not an electrician though.
Either way, you could secure the wires to the stud in the space between the boxes if you run out of the 1', or whatever distance. Then run the wires around the box, and secure them again above the top box. That would satisfy that rule.
(I've seen electricians do stuff like that before, but like I said, I can't quote electrical code.)
Cheers!
supers05 is offline   Reply With Quote
Old 10-20-2016, 09:16 PM   #6
Usually Confused
lenaitch's Avatar
Rewards Points: 824
Way off topic (and apologies to the OP - hopefully you will get satisfactory answers to your problem) but I have seen debates on whether the 'staple to box' distance is a straight line or run-of-wire distance. It all boils down to whatever the inspector will approve, but I also agree it is not super critical, especially when you consider that fished runs aren't bound by the same rules.
Old 10-20-2016, 09:49 PM   #7
hkstroud's Avatar
I agree that it is what ever the inspector will approve. However, I don't think running a cable down a stud can be considered fishing it through a wall, that is passing a cable through the holes bored in studs.
I am very interested in why the stud are oriented the way they are. I assume that what we see is the end of the wall. Curious as to how the rest of the wall is going to be built.
Old 10-20-2016, 09:53 PM   #8
Rewards Points: 366
Place a stacker staple on each side of the upper box and use the outermost tabs. It will secure the cables, keep them centered and away from the walls, and leave enough slack for them to go around the upper box.
Fishbulb28 is offline   Reply With Quote
The Following User Says Thank You to Fishbulb28 For This Useful Post:
lenaitch (10-20-2016)
Old 10-20-2016, 10:19 PM   #9
joed's Avatar
Rewards Points: 12,000
Not sure if what you propose is OK or not but you could drill through the stud and run the cables up the other side.
lenaitch likes this.
Old 10-21-2016, 12:41 AM   #10
hkstroud's Avatar
The only problem with that is, if I understand the environment correctly, the other side of the stud is the exposed end of the wall.
Old 10-21-2016, 08:55 AM   #11
joed's Avatar
Then drilling would not work.
Need Some Advice About A House With An Issue neutropia General DIY Discussions 7 01-29-2017 07:46 AM
Replacing retaining wall in front of old wall - options? dc300m01 Landscaping & Lawn Care 2 07-04-2016 10:43 PM
Connecting Ceiling Light/Fan. Multiple Switches. One switch box with three cables. AlpineB Electrical 7 04-12-2016 01:19 PM
GFCI outlets on other side of wall Tetranitrate Electrical 7 07-15-2011 09:06 PM
Open channels down each side of bonus room gable end wall from attic? fdecker Building & Construction 4 11-17-2010 05:28 PM
