Switches - Just Checking - Electrical - DIY Chatroom Home Improvement Forum
Old 10-06-2008, 09:31 AM   #1
I'm redoing some drywall in the bathroom and I came across this setup on two switches. 12/3 romex jumped across the two switches.
I have been told it's okay to use the same setup (with new box and switches), though I should pigtail into each of the switches rather than jumping directly from switch to switch. Is that correct?
I also have a small electric floor heater that the previous owner had installed. The house is a forced-air gas furnace, so this must have just been to keep her feet warm in the winter? The switch for the heater is a stud away from the box shown above.
My plan is to remove the floor heater and use that power to run a bathroom fan in the attic. I am going to install a new three-gang box where the old two-gang (above) was and then run some new 12/2 from the old heater switch to the new fan. Can I tie the ceiling fan neutral into the ceiling light in the attic?
Thanks for your help! I've read a lot on this site in the past, but this is the first time I've ever had to actually ask a question.
fuzzmartin is offline   Reply With Quote
Old 10-06-2008, 10:25 AM   #2
Rewards Points: 2,350
The two switch setup will work fine as you describe. The white is the hot with red and black as switch legs. You should also recolor the white.
What exactly do you mean by
You should use the neutral for the old heater for the new fan and keep neutrals from other circuits separated.
Old 10-06-2008, 11:39 AM   #3
That's what I was looking for, thanks!
Old 10-06-2008, 12:15 PM   #4
There is one problem I see here. You can't put 2 wires on one screw, have to pigtail the neutral.
rgsgww is offline   Reply With Quote
Old 10-06-2008, 12:17 PM   #5
It is likely that the wire is looped from one to the other, instead of two separate wires.
Old 10-06-2008, 12:25 PM   #6
Oh, I see it now, it looks ok then.
Old 10-06-2008, 12:42 PM   #7
Licensed Pro
But it's NOT a neutral... it's the constant hot (should be remarked).
Old 10-06-2008, 01:48 PM   #8
Thanks everybody. Yes, that is the constant hot. I am going to pigtail it and mark it as such.
The fan is on a separate circuit and it's going to get its own hot/neutral.
3 switches 1 light. need 2 lights 2 switches. Im desprete s richards Electrical 6 07-19-2008 03:18 PM
50+ year old home-all light switches one-way? mudpaw Electrical 13 06-22-2008 01:57 PM
light switches wired in series -- why? magnolia Electrical 2 05-11-2008 11:16 AM
Need help replacing switches in four-way circuit magnolia Electrical 3 05-09-2008 09:40 PM
grounding switches in old work plastic two gang box wkend2 Electrical 3 03-05-2008 12:33 PM
