Switches Have Me In Stitches - Electrical - DIY Chatroom Home Improvement Forum
Old 04-30-2012, 05:13 PM   #1
switches have me in stitches
i have 3 switch sets in my house that are giving me absolute fits.
#1 kitchen switch, controls the light over the outside door
Code:
3 sets of lines coming in,
line from the breaker panel (power)
line to the ceiling lights
line to the outside porch light.
i cannot get this 3 line to work without tripping the breaker every time i turn the switch off
#2 bathroom switches
Code:
power feed line
line to the light over the medicine cabinet
line to the second switch to control the exhaust fan.
same issue as the first set, flip the switch and trip the breaker (different breaker from the kitchen switch)
#3 living room switch and plug controlled via switch
Code:
 power feed line
outside porch light line
line to wall switch to control the lower wall outlet
flip switch, trip breaker
the switches i have are "1 pole" am i using the wrong switches for this job?
muaddib78 is offline   Reply With Quote
Old 04-30-2012, 05:15 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
Did this just start?
What changes have you made?
Old 04-30-2012, 05:20 PM   #3
cutting out older tan switches and installing new white switches and covers.
Old 04-30-2012, 06:42 PM   #4
after reading some topics on this site i have figured out the bathroom and living room but now im stuck on the kitchen
i have all the whites and grounds nutted together, the black from panel and to the ceiling lights on one pole and the porch light on the other.
the switch now works the outside light without popping the breaker but now the switch must be turned on to operate the ceiling lights.
Old 04-30-2012, 06:52 PM   #5
Master Electrician
Rewards Points: 3,960
Is this a mobile home?
brric is offline   Reply With Quote
Old 04-30-2012, 06:53 PM   #6
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
You have power for the second switch coming off the switched side of the other switch.
Old 04-30-2012, 07:10 PM   #7
a 73 modular (4 halves)
im not sure what that means.
Old 04-30-2012, 07:14 PM   #8
k_buz's Avatar
The wire that feeds the second switch must be moved to the screw with the single black wire to it.
Old 04-30-2012, 07:22 PM   #9
so move the black down to the other pole, the whites and grounds stay bundled correct?
Old 04-30-2012, 07:24 PM   #10
k_buz's Avatar
Whites should stay the same, one of the blacks (the one that isn't supposed to be controlled by the switch) should be with the black that is currently alone.
Old 04-30-2012, 07:32 PM   #11
Thank you!!!!!
It works now!!!!!
Two 3-way switches, one acting as a master switch? Ler0y Jenkins Electrical 10 02-28-2012 12:01 PM
Replacing old switches RyanS2000 Electrical 4 09-11-2011 03:21 PM
Question about switches on a 20 amp circuit Abs777 Electrical 6 04-28-2010 10:09 AM
Replacing switches turning into nightmare. RyanD Electrical 19 05-26-2009 06:19 PM
Need help replacing switches in four-way circuit magnolia Electrical 3 05-09-2008 09:40 PM
