Switches Burning Out - Electrical - DIY Chatroom Home Improvement Forum
Old 04-04-2013, 06:17 PM   #1
EJR
Switches burning out
I have a circuit that has been having trouble with switches burning out. The switches operate light fixtures. What could be causing the problem?
EJR is offline   Reply With Quote
Old 04-04-2013, 06:36 PM   #2
Rewards Points: 13,300
Loose nutral, voltage spikes, cheap switches, back stabbed instead of using the screws,
sirsparksalot (04-05-2013)
Old 04-04-2013, 08:16 PM   #3
Is it the switch to these lights?
Billy_Bob is offline   Reply With Quote
The Following 2 Users Say Thank You to Billy_Bob For This Useful Post:
Kyle_in_rure (04-04-2013), mpoulton (04-04-2013)
Old 04-04-2013, 10:26 PM   #4
Electrical Enthusiast
Rewards Points: 504
How many light fixtures are we talking about?
Do you ever notice anything unusual on this circuit besides switches going bad?
Kyle_in_rure is offline   Reply With Quote
Old 04-05-2013, 12:14 AM   #5
Rewards Points: 512
Are the switches rated for 125V?
Old 04-05-2013, 12:16 AM   #6
" Euro " electrician
frenchelectrican's Avatar
What is the system voltage ?
What kind of luminaire ( light fixure ) you have in there.
Once you answer that question plus other guy's comments then we will go from there.
Merci,
Marc
Old 04-05-2013, 12:55 AM   #7
dmxtothemax's Avatar
Rewards Points: 5,108
We need to know more about
1 - The size of the load, IE how many amps ?
2 - The nature of the load, IE what type of lights ?
discharge ? floro ? halogens ? incandesant ? CFL ? led ?
dmxtothemax is offline   Reply With Quote
weird wiring and wierd voltages on 3 dual switches... meweber1000 Electrical 5 12-18-2012 01:37 PM
Two 3-way switches, one acting as a master switch? Ler0y Jenkins Electrical 10 02-28-2012 01:01 PM
Wall Switches - with unknown termination cbjr Electrical 6 02-21-2012 09:15 PM
Replacing old switches RyanS2000 Electrical 4 09-11-2011 04:21 PM
Question about switches on a 20 amp circuit Abs777 Electrical 6 04-28-2010 11:09 AM
