#1 |
Switched Receptacle wiring advice required
I have an existing duplex receptacle in which both halves are switched (via a single switch). This is a middle of the run receptacle. It is currently wired as follows:
Coming in from the left (from another, unswitched outlet), there is one black (hot) and one White. From the right, there is one red (switched) and one black (hot). The white is attached to one of the neutral terminals and red to one of the hot terminals. Both tabs are still intact. The two black wires are connected via a wire nut. Thus, the switch turns on/off both outlets. I'm trying to figure out how to have only half of the outlet switched. My guess is that i need to break the tab, connect hot to one half and the switched wire to the other. But this leaves me with a spare hot, which I assume needs to be connected to the other hot. So do i need to add a small piece of black wire so that the two exising hots and the new wire can be connected together via the wire nut? Thanks for you help. |
#2 | |
Lic Electrical Inspector
Switched Receptacle wiring advice requiredQuote:
All responses based on the 2011 NEC. If you live in New Jersey click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . All other states click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Please check with local, county and state officials as laws may vary. Sizing motors To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Online motor calculator To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Online calculators To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . |
| The Following User Says Thank You to electures For This Useful Post: | stuvwxyz99 (09-23-2012) |
#3 |
Switched Receptacle wiring advice required |
#4 |
yes, put the existing blacks, and a short (6-8") piece of wire to go to the receptacle together with a connector of your choice
| The Following User Says Thank You to Techy For This Useful Post: | stuvwxyz99 (09-23-2012) |
#5 |
#6 | |
| The Following User Says Thank You to electures For This Useful Post: | stuvwxyz99 (09-25-2012) |
#7 |
#8 |
The existing (15A) receptacle is wired with 14 AWG wire. Is it ok to use 12 AWG wire for the pigtail? The wire nut would connect both 14 AWG along with the 12 AWG, and then the 12 AWG would also connect to one of the terminals on the receptacle.
#9 |
SOunds good.
| Tags |
outlet, switched, wiring ![]() |
| Display Modes | |
| 3-way Switch to always hot receptacle - wiring trouble | Waterfroggy | Electrical | 7 | 05-07-2012 11:00 PM |
| Need help wiring a switched outlet | Cmesposito | Electrical | 15 | 04-14-2012 11:33 AM |
| Thermostat wiring advice | tsugacanadensis | HVAC | 2 | 11-04-2008 08:04 AM |
| Hello...I need wiring advice | bradeja | Home Theater | 8 | 02-14-2008 05:24 PM |
| Wiring a 220v dryer receptacle | pjpjpjpj | Electrical | 8 | 06-05-2007 05:08 PM |
