Switched Receptacle Question - Electrical - DIY Chatroom Home Improvement Forum
Old 11-21-2010, 08:48 PM   #1
Rewards Points: 83
I tried to replace a worn-out receptacle today, but am having a small problem, which I am sure is quite simple for anyone but a novice like myself. The top half of the receptacle is controlled by a wall switch.
On the brass terminal side, the old receptacle had a red wire connected to one of the two upper push-in slots, and two black wires connected to the two lower push-in slots. There were two white wires connected to the push-in slots on the silver terminal side of the receptacle.
Since this is a switched receptacle, I guess I need to remove the connector tab between the top and bottom halves of the receptacle. But my new receptacle only has one push-in slot -- I usually prefer to use the terminals anyway. If I connect the red wire to the upper brass terminal, how do I connect both black wires to the lower terminal? Use a jumper from the lower brass terminal and connect the black wires with a wire nut?
Thanks for your help.
MrBill_DIY is offline   Reply With Quote
Old 11-21-2010, 08:50 PM   #2
joed's Avatar
Rewards Points: 11,548
If the receptacle only has a one screw terminal then you need to nut the two black wires with a third short black wire which is connected to the terminal.
Old 11-21-2010, 10:05 PM   #3
Rewards Points: 83
Okay, thanks, that's what I did. I suppose you could also connect one black wire to the brass terminal and the other one to the slot. But I wasn't sure whether that is allowed.
Old 11-21-2010, 11:07 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 138
That would be allowed.
Isolated Ground Receptacle Bocolo Electrical 40 01-23-2012 03:44 PM
Outdoor Receptacle Box Question RST Electrical 1 10-17-2010 09:18 PM
Receptacle Rating question Ultrarunner2017 Electrical 19 12-20-2008 07:20 PM
Question with wiring up a flood light. SuperAkuma Electrical 6 09-20-2008 11:58 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
