Switched Plug Issue - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-20-2011, 12:04 AM   #16
Thadius856's Avatar
Rewards Points: 504
Originally Posted by n0c7 View Post
This is a brand new house and this is what contractors do these days to save time. I don't disagree with using the screws over the backstabs.
That's what I figured. I noticed marking on a new outlet today that indicated you could use the lobes on the mounting bracket to strip 12 awg on one side and 14 awg on the other. Made me shudder.
Thadius856 is offline   Reply With Quote
Old 07-20-2011, 06:12 AM   #17
Rewards Points: 1,548
So by doing this I'm leaving one of the screws empty. Why even bother using a 3-way switch? Should I change the switch out to a single pole?
Yes you can leave one of the light colored screws empty. No need to make another trip to the store now to get a single pole switch (unless you need the 3 way switch elsewhere).
The Following User Says Thank You to AllanJ For This Useful Post:
n0c7 (07-20-2011)
Old 07-20-2011, 03:29 PM   #18
Rewards Points: 518
Looks like these are some new style Decora switches I haven't encountered before. You cannot remove the wires once inserted in the jab(no release tab anymore) and they are labelled "DO NOT REUSE ONCE WIRE IS INSERTED". I guess I could cut off the wire flush at the stab and then use the screws but for $0.30 I might as well get a new single pole.
n0c7 is offline   Reply With Quote
Glasshouse heater plug melting stuie Electrical 7 04-21-2009 10:54 PM
HELP - with my breaker box. Interesting issue. LordX Electrical 75 02-23-2009 03:14 PM
240 v Space heater plug? CooperChloe Electrical 12 02-04-2009 10:57 PM
Leaking main drain clean out plug bucksone Plumbing 1 01-10-2009 07:42 AM
GFI Plug Troubleshooting bryanchr Electrical 4 08-22-2008 05:28 PM
