Switched Outlet's - Electrical - DIY Chatroom Home Improvement Forum
Old 10-01-2011, 11:34 AM   #1
Osh
Rewards Points: 32
switched outlet's
Not the sharpest knive in the sock drawer so here goes. Recently repainted room that had 5 outlets, one half of each outlet was switched. I replaced all outlets one at a time no I wouldn't get confused with wireing setup. Switched outlets didn't work so searched the internet and found I should have cut the connection between the brass terminals. Did all except 1 behind bed. tested outlets on either side of the hidden outlet and still no joy. Is that the culprit?
wireing is the following.
1st outlet in room has 1red 1white and 1yellow
2nd, 4th and I assume 3rd that I can't get to have 2 of each color
5th outlet has 2 reds 2whites and 1 yellow
switch has 1 of each with white and yellow on same terminal, same as 1st outlet in room.
Shouldn't be this difficult , any help appreciated. All outlets have power full time.
Osh is offline   Reply With Quote
Old 10-01-2011, 12:02 PM   #2
Rewards Points: 1,538
Do they now still all have power all of the time?
Start over with your description, with a separate paragraph for each outlet and what wires are connected where. (not groups such as "second and third are like this".)
Be sure that wire ends are curved to wrap around the screws but not sticking out to touch the next screw or nearby metal not under the proper screw.
You're sure you snapped off the metal tabs connecting screw terminals next to each other in the same way the old receptacle (outlet) units were done?
Old 10-01-2011, 12:03 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,228
The 1 receptacle that you did not remove the brass tab is back feeding to the other receptacles. Break the tab in that 5th receptacle.
Coastal South Carolina
Old 10-01-2011, 12:37 PM   #4
Osh
Rewards Points: 32
Rjniles, that was the answer. Thanks alot.
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 12:29 PM
Wiring two switched outlets. drken Electrical 3 08-01-2011 08:01 PM
Supplemental Outlets in 1950's House Perry401 Electrical 2 05-01-2011 08:49 PM
series of 1/2 switched outlets chiefsfantrish Electrical 20 08-16-2010 12:08 PM
Wiring for switched, split power outlets ELurie Electrical 9 06-21-2007 07:12 PM
