Switched Outlet Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 05-22-2012, 11:03 AM   #1
Rewards Points: 81
Hey guys,
How does this look? I think I mapped it correctly...14-2 to the switch and then 14-3 to both outlets. I'm not sure what is better to have controlled by the switch (top or bottom) but I believe the pictured wiring is for bottom to be controlled by the switch (I know I need to remove the tab)
LarryM is offline   Reply With Quote
Old 05-22-2012, 11:08 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
I know you know this, but you have the red and the white going to the same side of the receptacle.
Just make sure you break the tab on the hot side.
Old 05-22-2012, 11:49 AM   #3
both hots should be on the same side with the tab broken and there is no neutral in the switch box.
Old 05-22-2012, 12:14 PM   #4
kevinp22's Avatar
Rewards Points: 252
I switched the bottom with the thinking that switched items are likely to be plugged in all the time and those cords, if on top, might block the lower one slightly. but it really is a personal preference thing.
kevinp22 is offline   Reply With Quote
Old 05-22-2012, 12:37 PM   #5
Rewards Points: 81
Thanks guys, sorry for the crappy picture above I knew about the Hots being on the same side but some reason didn't draw it.
So I am going to follow this diagram except that I will wire nut the Red (Hot) and White (Neutral) at the first outlet and match it up to the 2nd with the 14-3 as well as break the tab on the 2nd outlet
Another simple question assuming the above is correct.
For rough in inspection: My sub panel should or should not have the wires in place from the main panel? and Circuits should not be installed in the sub panel, just the stripped cables hanging loosely
Old 05-22-2012, 01:51 PM   #6
jbfan's Avatar
Rewards Points: 650
I make anything and everything that can be made before the rough.
That means less work at the trim.
Help wiring new outlet Wnt2bsleepin Electrical 15 09-08-2011 11:53 AM
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 03:36 PM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 09:05 PM
Turning Switched Outlet Into Ceiling Fixture 39centstamp Electrical 10 06-08-2007 12:07 PM
Troubleshooting bedroom outlet wiring? Operator4819 Electrical 15 04-01-2007 08:10 PM
