Switched Outlet And Running New Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 07-02-2011, 06:41 PM   #1
Rewards Points: 162
Switched outlet and running new wire
I have 2 outlets I'd like to make half switched. Right now, the outlets are full switched. I understand I need to run a single hot wire to the outlet for the always hot half. Am I required to run new wire all the way from the panel? Or can I cut another existing line in half, stick it in a junction box, and splice everything together?
Also, can I run a single regular plain wire to the outlet or do I have to use romex and only utilize the black wire in it?
matt151617 is offline   Reply With Quote
Old 07-02-2011, 07:38 PM   #2
DIY staff
Rewards Points: 7,174
If you do not have conduit ,you will need to run new romex to that box--no unshielded wires inside the walls
you should be able to draw that circuit from any near by J box that has adequate power.
A licensed electrician will correct me if I screwed you up. They are all at a barbecue and I wasn't invited. (I'm old grumpy and have no sense of humor)--Mike---
Old 07-02-2011, 08:40 PM   #3
Missouri Bound's Avatar
You already have a hot wire at the switch. If you have conduit you can run 1 wire from the switch to the outlet to power it. If you don't have conduit you will be installing a cable.
Old 07-02-2011, 08:45 PM   #4
Electrician
SD515's Avatar
Rewards Points: 504
Originally Posted by oh'mike View Post
...They are all at a barbecue and I wasn't invited. (I'm old grumpy and have no sense of humor)--Mike---
Was wondering why you didn't RSVP
Have you opened up the receptacle and switch boxes, and looked if there is already another wire not being used (capped off)?
Kyle
Old 07-02-2011, 09:35 PM   #5
Rewards Points: 162
There are no extra wires not being used.
If new romex needs to be run maybe I'll just have an electrician install 2 new outlets. Since this is where my computer and tv plug into, I could ensure the best new wiring. Any rough estimates from electricians of what 2 new outlets would cost as opposed to wiring up the switched outlets?
Old 07-03-2011, 12:23 AM   #6
" Euro " electrician
frenchelectrican's Avatar
The actual cost will really varies a bit all it depending on the structure et how much room you have in the breaker/fuse box and the labour rates it will varies a bit.
So if you really want to know the cost the best answer is have couple electricians make a bid for you have at least 3 bids and go from there.
Merci,
Marc
Old 07-03-2011, 06:45 AM   #7
DIY staff
I like your idea of running a new dedicated circuit (or two) for your computer station.
I don't like sensitive equipment on a line that has a lot of other uses---especially any high amp items that could cause power fluctuation when they start up.
Old 07-03-2011, 10:55 AM   #8
Rewards Points: 162
That would be nice, but I'm not sure how cost-effective it would be. The only thing plugged into my living room circuit is a couple of lamps. Without the electronics the circuit is pretty much unused.
The Following User Says Thank You to matt151617 For This Useful Post:
oh'mike (07-03-2011)
Switched outlet series Overkll Electrical 4 12-07-2010 07:38 AM
Adding ground in old home ChaosTheory Electrical 6 06-16-2010 04:02 PM
Branching off Switched Outlet BaconK5 Electrical 7 01-22-2010 05:56 AM
Outside: Adding an outlet to a switched light fixture indigo Electrical 9 12-15-2009 09:48 AM
running wire underground for outdoor outlet ponch37300 Electrical 11 06-26-2009 09:41 AM
