-   -   Switched outlet and running new wire (http://www.diychatroom.com/f18/switched-outlet-running-new-wire-109486/)
matt151617 07-02-2011 06:41 PM
I have 2 outlets I'd like to make half switched. Right now, the outlets are full switched. I understand I need to run a single hot wire to the outlet for the always hot half. Am I required to run new wire all the way from the panel? Or can I cut another existing line in half, stick it in a junction box, and splice everything together?
Also, can I run a single regular plain wire to the outlet or do I have to use romex and only utilize the black wire in it?
oh'mike 07-02-2011 07:38 PM
If you do not have conduit ,you will need to run new romex to that box--no unshielded wires inside the walls
you should be able to draw that circuit from any near by J box that has adequate power.
A licensed electrician will correct me if I screwed you up. They are all at a barbecue and I wasn't invited. (I'm old grumpy and have no sense of humor)--Mike---
Missouri Bound 07-02-2011 08:40 PM
You already have a hot wire at the switch. If you have conduit you can run 1 wire from the switch to the outlet to power it. If you don't have conduit you will be installing a cable.
SD515 07-02-2011 08:45 PM
Originally Posted by oh'mike (Post 678730)
...They are all at a barbecue and I wasn't invited. (I'm old grumpy and have no sense of humor)--Mike---
Was wondering why you didn't RSVP :(
Have you opened up the receptacle and switch boxes, and looked if there is already another wire not being used (capped off)?
matt151617 07-02-2011 09:35 PM
There are no extra wires not being used.
If new romex needs to be run maybe I'll just have an electrician install 2 new outlets. Since this is where my computer and tv plug into, I could ensure the best new wiring. Any rough estimates from electricians of what 2 new outlets would cost as opposed to wiring up the switched outlets?
frenchelectrican 07-03-2011 12:23 AM
The actual cost will really varies a bit all it depending on the structure et how much room you have in the breaker/fuse box and the labour rates it will varies a bit.
So if you really want to know the cost the best answer is have couple electricians make a bid for you have at least 3 bids and go from there.
Merci,
Marc
oh'mike 07-03-2011 06:45 AM
I like your idea of running a new dedicated circuit (or two) for your computer station.
I don't like sensitive equipment on a line that has a lot of other uses---especially any high amp items that could cause power fluctuation when they start up.
matt151617 07-03-2011 10:55 AM
That would be nice, but I'm not sure how cost-effective it would be. The only thing plugged into my living room circuit is a couple of lamps. Without the electronics the circuit is pretty much unused.
