Switched Outlet Currently But Want To Add A Fan/light - Electrical - DIY Chatroom Home Improvement Forum
Old 04-13-2013, 02:35 PM   #1
Switched outlet currently but want to add a fan/light
Good Afternoon,
I am planning on adding a fan with a light into a bedroom. The bedroom has no existing ceiling light, only a switched outlet.
Heres the info:
Switch
3 romexs cables coming in to the box
2 are 14-2 one is 14-3
All blacks are wire nutted with a jumper going to the bottom of switch. All whites and ground wire nutted together (seperately).
One red going to the top of the switch.
The outlet:
1 14-2, 1 14-3 coming in
On top the red is connected. The brass piece on the side is removed to seperate the top from bottom.
Two black wires are connected to the bottom terminal and white is on the other side.
So now i want to know whats the easiest way to make the outlet always powered and then add a ceiling fan?
For the outlet I am assuming, I cap the red and put in a new outlet as a normal series outlet is wired.
For the switch again cap the red. Then just run a wire into the box and to the fan?
Thanks in advance for your help.
rpratt84 is offline   Reply With Quote
Old 04-13-2013, 02:44 PM   #2
Banned Electrician
HARRY304E's Avatar
Rewards Points: 204
Originally Posted by rpratt84 View Post
Good Afternoon,
Heres the info:
Switch
The outlet:
Buy a new receptacle and replace the old one ,Cap off the red wire in both boxes,Run a 14/3 to that fan location so you can switch the light and fan separate,Turn the switch box into a two gang box the red from the 3 wire goes to one switch the black goes to the other.
"Government is not the solution to our problem; Government is the problem."
HARRY304E is offline   Reply With Quote
Old 04-13-2013, 02:55 PM   #3
Thanks for your help!
Is the two light switches so I can turn the fan and lights on seperately? Can I keep the single gang box and only do one switch?
Old 04-13-2013, 02:57 PM   #4
Banned Electrician
HARRY304E's Avatar
Rewards Points: 204
You will wined up with too many wires in one box so you are better off making it a 2 gang,Yes that is what the 2 switches are for.
The Following User Says Thank You to HARRY304E For This Useful Post:
rpratt84 (04-13-2013)
Old 04-13-2013, 03:01 PM   #5
Perfect, Thank you!
Old 04-13-2013, 03:02 PM   #6
Banned Electrician
HARRY304E's Avatar
Rewards Points: 204
Perfect, Thank you!
You're Welcome.
Old 04-13-2013, 03:04 PM   #7
If you want to have one switch you can replace the box with a double gang and only have 1 switch in it.
jsbuilders is offline   Reply With Quote
Possible to wire constant outlet from switched outlet? MikesHouse Electrical 11 11-12-2012 10:14 AM
Odd voltages at outlet TJF Electrical 12 11-01-2011 09:13 PM
how do I make the last outlet switched? dancram Electrical 5 10-26-2011 09:30 PM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 09:05 PM
Turning Switched Outlet Into Ceiling Fixture 39centstamp Electrical 10 06-08-2007 12:07 PM
