Switched Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 06-01-2008, 12:07 PM   #1
Switched outlet
Power supply from switch to outlet to exterior light. Want to at receptacle to be constant, at least split, but keep the exterior light switched. Can this be done without running new wire?
dhageman is offline   Reply With Quote
Old 06-01-2008, 12:20 PM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Need a little bit more info. Does the wiring go the way you explained (switch, to the outlet and out to the light) or are they both fed out of the switch box (you would have 3 cables in the switch box) Is the whole receptacle switched or just 1/2 of it (top or bottom)?
wirenut1110 is offline   Reply With Quote
Old 06-01-2008, 12:26 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,878
I agree with nut. Please try again with a few more details.
Old 06-01-2008, 04:48 PM   #4
joed's Avatar
Rewards Points: 12,008
What cable is between the switch and the receptacle? If it is not a 3 wire+ ground then you can 't do it if the cabling is switch-receptacle- light.
Old 06-01-2008, 05:06 PM   #5
Not likely. You need a 3 wire 1 hot, 1 switch leg and 1 netral.
You probably only have a 2 wire, 1 hot and 1 neutral.
You could install a photo cell at the outlet that would turn the fixture off during the day and just leave the switch on.
You could also make the sw leg hot and install a wireless switch for the light.
220/221 is offline   Reply With Quote
Old 06-01-2008, 09:30 PM   #6
So what is the question?
Super33 is offline   Reply With Quote
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 10:05 PM
Looking for help in testing why switched outlet is always hot geocrash Electrical 3 11-26-2007 08:15 PM
Switched Outlet with humidistat. Clutchcargo Electrical 3 06-21-2007 06:20 PM
Turning Switched Outlet Into Ceiling Fixture 39centstamp Electrical 10 06-08-2007 01:07 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 09:45 AM
