Switched Lighting Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 03-22-2013, 07:22 PM   #1
Want to Learn
jonhayden's Avatar
Rewards Points: 135
Hey guys,
Sorry for the newbie question. I was looking through some helpful documentation that came with my basement finishing permit. It mentions that the bedroom requires a switched lighting outlet. Is that the same thing as a fixed light that's controlled by a switch? Or does that mean I have to install a switched outlet that you can plug a lamp in to? I despise those switched outlets to be honest. My plan has 3 switches at the entrance to the bedroom...1 for some recessed lights, 1 for a fan, and 1 for some wall sconces. I have no desire to add a 4th switch to control a plug outlet. Can someone clarify what a switched lighting outlet is?
Thanks for the help!
Jon
jonhayden is offline   Reply With Quote
Old 03-22-2013, 07:30 PM   #2
Licensed electrician
Rewards Points: 1,884
Either a switched receptacle or a lighting outlet like the recessed will satisfy the requirement. You do not need both.
jonhayden (03-22-2013)
Old 03-22-2013, 07:33 PM   #3
Rewards Points: 512
People often confuse the term "outlet" with "receptacle". Actually, an outlet can be either a receptacle, junction box, lighting fixture, others I'm not recalling, I guess.
But I think you're fine with either a switched ceiling light fixture, or a switched receptacle.
No Code to cite, others will, probably.
EDIT: aha! Outlet: A point on the wiring system at which current is taken to supply utilization equipment. Article 100. DEFINITIONS.
The Following User Says Thank You to sirsparksalot For This Useful Post:
Old 03-22-2013, 07:38 PM   #4
Want to Learn
jonhayden's Avatar
Rewards Points: 135
Thanks! Learn something new everyday
Old 03-22-2013, 08:59 PM   #5
joed's Avatar
Rewards Points: 13,740
A junction box would not be considered an outlet. Only something that draws power is an outlet. Receptacles, fans, light fixtures are the typical outlets found in a home. Switches and junction boxes with connections only are not outlets.
The Following User Says Thank You to joed For This Useful Post:
sirsparksalot (03-22-2013)
Old 03-22-2013, 09:09 PM   #6
Rewards Points: 512
I stand corrected (in a seated position)
Old 03-22-2013, 09:12 PM   #7
Rewards Points: 512
Now wait just a doggone minute "... to supply utilization equipment". A luminaire utilizes a switch
Old 03-23-2013, 06:35 AM   #8
Rewards Points: 1,548
The same box could be a switch box, an outlet box, or a junction box. In the case of the outlet box that is where the (#12 or #14 or whatever gauge) branch circuit wires are connected to the terminals of a receptacle or to the (possibly #18 gauge) leads/taps to a light fixture or a fan or a garbage disposal, etc.
Old 03-23-2013, 09:13 AM   #9
joed's Avatar
If the device controlled by the switch(utilization equipment) connects into the switch box then the switch box is an outlet. The switch itself is not utilization equipment and if it is the only thing in the box then it is not an outlet.
Old 03-23-2013, 09:31 AM   #10
Rewards Points: 512
OK, my above posts were attempts at lighthearted fun, and the chance to use and understand my brand new hard copy of the '08 Code I just got for $20., but now you've thrown me a loop
How could it be that a switch could be the only thing in the box if it is controlling a device? Or, how could a device not be connected to a switch that is meant to operate it?
How to turn light switch into switched outlet? bobgodd Electrical 3 10-28-2012 07:50 PM
wiring ceiling fan to switched outlet bronkorob Electrical 1 06-11-2012 07:17 AM
troubleshooting 3 way switched outlet pyper Electrical 13 05-16-2011 01:34 PM
Adding Ceiling Light From Switched Outlet vboz5 General DIY Discussions 2 03-04-2009 12:53 PM
Turning Switched Outlet Into Ceiling Fixture 39centstamp Electrical 10 06-08-2007 12:07 PM
