Switched GFCI - Electrical - DIY Chatroom Home Improvement Forum
Old 03-20-2010, 10:45 PM   #1
Post
Switched GFCI
Hi guys, hope I'm clear enough in my description. I have power (15 amp - 14-2 wire) coming in to a light fixture, then, to a single gang box with a switch that has two switches in one unit. Here's how I wired it. (All grounds are together). At the light fixture, white line in, to the white wire on the fixture. Black line in, to the White wire (colored black to show hot on both sides) going to the switch. The Black wire from fixture goes to the black wire going to the switch. At the switch box, White wire (Hot) to the top switch, common. The Black wire from fixture goes to the other terminal. Everything here seems to be working fine. Here's where I'm having trouble. The second switch will power a GFCI plug.
The Black wire (from the second 14-2 wire), goes from the common on the bottom switch to the Hot Line In, Brass Terminal, on the GFCI plug. The White wire goes to the Line In, Silver Terminal, on the GFCI plug. I have power to the GFCI outlet. When the switch is off, I have power to the Brass Terminal, when the switch is on. I have power to both the Brass and the Silver Terminals. The GFCI won't reset and has no power in the plugs. Hope you can help, thanks.
CRay
CrazyRay is offline   Reply With Quote
Old 03-20-2010, 11:02 PM   #2
It sounds like you have the second switch/outlet wired into the switch leg and don't have common.
hayewe farm is offline   Reply With Quote
Old 03-20-2010, 11:05 PM   #3
joed's Avatar
Rewards Points: 13,694
You can't do it. You don't have a neutral. You need 14/3 from the fixture to the switch to make this work.
Old 03-20-2010, 11:15 PM   #4
There is a copper tab still connected on the double swith. Shouldn't that provide power from the common side out to the GFCI? Is that what you're
referring to?
Old 03-20-2010, 11:37 PM   #5
You have hot on the buse of the double switch the output of the switch is hot and goes to the GFCI but you have no neutral, the white wire on the switch is a redesignated hot. You need to have a neutral wire from the power lead (the same one connected to the white wire on the light) to provide neutral to the GFCI.
Old 03-20-2010, 11:49 PM   #6
Here's a quick drawing of what you should have
Old 03-21-2010, 12:05 AM   #7
Ok, this really helps, thank you very much, especially for the drawing. I'll tackle this first thing in the morning. I'll let you know as soon as I'm done. BTW, I'm on Hawaii Standard Time.
Old 03-21-2010, 10:59 AM   #8
joed's Avatar
referring to?
Your problem is not providing power to the GFCI. It is providing a neutral. There is not neutral unless you run a three wire cable from the fixture to the switch.
Old 03-21-2010, 02:10 PM   #9
Ok, it's 9am in Hawaii. Just finished my Kona Coffee. Gotta run down to Home Depot for some 14/3 wire. (The hazards of having a 28yr old son that knows how to remodel) I'll let you know as soon as I finish. Thanks again.
Old 03-21-2010, 05:46 PM   #10
Awesome, we are checking out at 100%. My plug tester lights, show all is "correct" with the GFCI plug and it's working fine too.
Thank you everyone. I'm real glad I found this forum.
CRay
Tags
switched gfci wiring
Freezer tripping GFCI davidclements Appliances 58 07-03-2015 05:46 AM
Gfci Circuit howard.wheaton Electrical 10 01-29-2009 05:14 PM
GFCI and Switched Receptacle cygnl7 Electrical 14 12-01-2008 07:14 AM
GFCI Question Mdbuilder Electrical 6 06-19-2008 03:15 PM
GFCI questions 5circles Electrical 4 11-05-2007 08:24 PM
