Switch Wiring Issue - Electrical - DIY Chatroom Home Improvement Forum
Old 01-25-2013, 12:47 AM   #1
braves22's Avatar
Switch wiring issue
Ok so here's the sitch...
Had two single pole switches connected one to a light and the other to a fan which are tied into the ceiling.
Anyways I am changing out the switches for a rocker and 3 speed fan control. The problem is I have full control of the fan but the light for the rocker switch will not go off. I thought there could be an issue bc the left switch which controlled the light was hooked up with a red up top and black at the bottom...when I correspond it to the new switch there is always power no matter whether the rocker is up or down...can someone help me...thx
braves22 is offline   Reply With Quote
Old 01-25-2013, 01:09 AM   #2
MCB
sparky
Three wire to the ceiling, probably red switching the lamp and black switching the fan...are you sure it's hooked up the same?
MCB is offline   Reply With Quote
Old 01-25-2013, 01:20 AM   #3
braves22's Avatar
When I took out the two single on off simple switches they had red/black on the switch to the light and black with white paint and black on the right switch to the fan...
All I did was hook up the 3 speed fan control like it said while using the 2 wires that were connected to the previous switch...
I will rewire it however it should be done...
Here's what I have, I have 2 blacks coming from a pigtail, 1 to the left and 1 to the right and a red coming in and a black coming in.
Old 01-25-2013, 01:21 AM   #4
braves22's Avatar
And at my ceiling it's red to the fan and black to the light
Old 01-25-2013, 01:24 AM   #5
MCB
sparky
Sounds like the pigtailed blacks should go to each new switch each and the red one controls whichever it sends power to : fan? And black to lamp
Old 01-25-2013, 01:27 AM   #6
MCB
sparky
The pigtailed blacks should be hot and the other two are the switched ones
Old 01-25-2013, 01:34 AM   #7
braves22's Avatar
Ok so if that's the case, then i imagine the pigtail black goes on top and the black painted white goes on bottom for the rocker switch? And then pigtail black to black and red to red for the fan side switch
Is that correct?
My question is, if that is also the case, why does the fan work with out the red connected to the fan switch?
Old 01-25-2013, 01:54 AM   #8
MCB
sparky
Do you have a tester or a meter to see which wires are hot and which are switch legs?
Shouldn't matter which one you attach it to as long as it doesn't say line and load on the switch/rocker/fan control.
One will be the hot from a source, pigtailed to supply power to both switches, and the other two will supply the switched power to the fan and the light.
If there is line and load on either rockers or fan controls, the hot is the line.
Old 01-25-2013, 02:05 AM   #9
MCB
sparky
a pic of the switches you are using might be helpful...
Old 01-25-2013, 09:24 AM   #10
braves22's Avatar
Here is the link to the leviton rocker switch:
http://www.leviton.com/OA_HTML/Produ...minisite=10251
And here is the fan control: (note, I am not using the on/off scheduled to use for a light)
http://www.lutron.com/TechnicalDocum...ry/033039c.pdf
Here are the images of the items:
Old 01-25-2013, 01:38 PM   #11
Resi EC
Rewards Points: 252
How about a pic of the wiring with the switches you're having trouble with
Gac66610 is offline   Reply With Quote
Old 01-25-2013, 01:52 PM   #12
braves22's Avatar
A little difficult to do sitting at my desk at work when they're at home chief
Old 01-25-2013, 10:51 PM   #13
braves22's Avatar
Ok here are the pics you were looking for:
Wiring to Replace Timer Switch with Single Pole Switch BusterT Electrical 2 10-26-2012 04:39 PM
Backyard wiring questions MikeInDetroit Electrical 1 11-02-2011 10:46 AM
Fan Wiring Installation Issue cca10 Electrical 1 05-03-2009 06:29 PM
Light Switch to Detached Garage - Grounding Issue smitty286 Electrical 1 10-22-2008 01:17 PM
3-Way Switch Wiring MrBill_DIY Electrical 8 09-07-2008 06:53 PM
