Switch Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 06-24-2012, 12:33 PM   #1
Rewards Points: 81
Switch Wiring
I am 2 multi gang boxes away from rough in inspection and confirming I have this setup correct.
From left to right
The 1st wire is an outgoing wire for 2 lights above cabinets.
The 2nd wire is incoming power for the 1st set of wires
The 3rd wire is an incoming 3 way from the other switch location (the other switch is fed power from the circuit)
The 4th wire is an outgoing 14-2 wire for the 3 way lights
The 4 wires all share the same circuit thus I nutted all the grounds together except I did not nut the neutrals together. Should the white neutrals all be nutted?
Did I need to run the 2nd wire (incoming power for non 3 way light)? Could I have used the power from the incoming 3 way? I don't think so since I believe either back or red is hot???
The 5th and 6th wire all the way to the right is for a middle of run 20 amp receptacle and an end of run 20 amp receptacle. (obviously on its own circuit)
LarryM is offline   Reply With Quote
Old 06-24-2012, 01:35 PM   #2
Master Electrician
Rewards Points: 3,698
ALL grounds of all circuits should be tied together. IMO the description of the 3-way is inadequate to make an assessment.
brric is online now   Reply With Quote
Old 06-24-2012, 01:40 PM   #3
Rewards Points: 2,512
just a terminology note
hammerlane is offline   Reply With Quote
Old 06-24-2012, 01:49 PM   #4
Rewards Points: 81
Interesting, I didn't know all grounds should be tied together even if they are different guages and different circuits. I'll tie them together that being the case. Thinking about it and it does make sense.
Regarding the 3 way. There is another 3 way switch at the entrance of the room and the start of the run. The main circuit branch is tied into that room entrance box. From the entrance box a 14-3 cable is run to the box pictured above and tied to a 3 sway switch which will have a 14-2 going to the lights. Should the neutrals all be tied together?
Old 06-24-2012, 01:50 PM   #5
Rewards Points: 81
Old 06-24-2012, 01:55 PM   #6
Are you installing a 3-way switch in the box pictured??
Old 06-24-2012, 01:56 PM   #7
Rewards Points: 81
Yes there will be
Old 06-24-2012, 01:59 PM   #8
Master Electrician
your what i like to call a "super twister". nothing wrong with it, just harder to troubleshoot and bend the wires into the box when they're twisted up as far as they can go.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 06-24-2012, 01:59 PM   #9
Which one is the power coming in? are there two different circuits in that box?
CopperClad is offline   Reply With Quote
Old 06-24-2012, 02:01 PM   #10
Not sure I completely understand your setup but by your question I assume that you have separate circuits in the box pictured and want to know if the neutrals can be tied together?
Old 06-24-2012, 02:20 PM   #11
Rewards Points: 81
I'm new at so I can change I thought it looked cleaner so going forward I'll do it about half way.
Old 06-24-2012, 02:24 PM   #12
Rewards Points: 81
Yes, 2 different circuits
The right 20 amp cable is on a 20 amp circuit. An outlet will be located there. Tough to see but there is another 20 amp cable in there going to another outlet.
The left 4 cables are for 2 light switches on a 15 amp circuit.
1st cable is an outgoing wire for 2 lights above cabinets.
2nd cable is incoming power
3rd cable is an incoming 3 way from the other switch location (the other switch is fed power from the circuit)
4th cable is an outgoing 14-2 wire for the 3 way lights
Old 06-24-2012, 02:27 PM   #13
Rewards Points: 81
The neutrals on the 20 amp cable and 15 amp cable I don't believe should be tied together.
I'm curious if the neutrals on cable 1 and cable 2 (currently twisted) should be tied to neutrals on cable 3 and cable 4 (currently twisted)
Cables 1-4 share a 15 amp circuit
Cables 5 and 6 are 20 amp on a 20 amp circuit
Old 06-24-2012, 03:00 PM   #14
Cables 1 thru 4 neutrals can be "twisted together"
Cables 5 and 6 can be "twisted together" but kept separate from cables 1 thru 4's neutrals.
If this was part of a MWBC(multi-wire branch circuit) all neutrals can be tied together. A handle-tie at the panel or other indication should indicate that the two breakers are part of a MWBC so both should be shut down when working on either circuit of a MWBC.
You do not want to share neutrals on different circuits because you could have the breaker going to cables 1 thru 4 off but current is still "traveling" on the neutral of cables 5 and 6 and could bite you.
Old 06-24-2012, 03:17 PM   #15
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
I don't believe you could do that, the 3 way is fed from the other end, if he brought his feed from that same box, and you tied all the neutrals together, you would be creating a parallel connection with the neutrals, and a code violation of 310.4
The way the OP has them made up is correct.
The Following User Says Thank You to stickboy1375 For This Useful Post:
LarryM (06-24-2012)
Help Wiring Dimmer Switch scubakathy84 Electrical 2 12-21-2011 11:26 PM
Simple question regarding Wall Switch wiring kebrein Electrical 6 11-25-2011 08:54 PM
Wiring an Intermatic Wall Timer in a three way switch aitutaki98 Electrical 6 07-23-2011 12:43 PM
Unusual three way switch wiring help r1racer Electrical 9 11-11-2010 09:49 PM
Switch on K&T wiring - OK to pigtail? fdmillion Electrical 4 01-27-2010 10:15 AM
