Switch Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 01-29-2012, 06:41 PM   #1
Switch wiring
I have a limited knowledge of wiring--enough to change a switch if everything looks as expected. I pulled out a light switch today and found an unexpected connection.
At one connection on the switch, the black, incoming current, wire is connected onto the side screw, and a red wire ( other end goes to an unswitched outlet) is plugged into the back at the same position. The rest of the connection at the switch made sense to me.
It seems like this double connection is using the switch as a bridge between the black and red to power the unswitched outlet. It has worked fine but I'm wondering is this safe/ to code?
Out2pasteur is offline   Reply With Quote
Old 01-29-2012, 06:43 PM   #2
Old 01-29-2012, 06:58 PM   #3
Licensed electrician
Rewards Points: 996
You are correct that the switch is acting as a wire nut to connect the black to the red. Many would prefer to pigtail ta connection like that, but what you have is a code legal method. It will not be as reliable as a pigtail.
Old 01-29-2012, 07:05 PM   #4
Thanks!
Old 01-29-2012, 07:20 PM   #5
Hey Jim I don’t use the back stab at all. I am not disputing that using the switch as a wire nut is code. But why would they allow that?
Also there is an outlet on that switch, I don’t see a neutral. Am I missing something?
Hardway is offline   Reply With Quote
Old 01-29-2012, 07:25 PM   #6
Rewards Points: 996
The device have been tested to allow those connections by UL.
The problem is that they rely on a small area of spring material to make the connection which becomes less springy over time with heavy loading and starts to fail.
Old 01-29-2012, 07:28 PM   #7
I have remove outlets for what ever reason and have had the back stabbed wire slide right out,
Old 01-29-2012, 07:46 PM   #8
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Some cities do not allow back feeding of plugs/switches,they require everything to be pigtailed before the plug/switch
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 01-29-2012, 07:51 PM   #9
the only way to go!
Help Wiring Dimmer Switch scubakathy84 Electrical 2 12-21-2011 11:26 PM
Simple question regarding Wall Switch wiring kebrein Electrical 6 11-25-2011 08:54 PM
Wiring an Intermatic Wall Timer in a three way switch aitutaki98 Electrical 6 07-23-2011 12:43 PM
Unusual three way switch wiring help r1racer Electrical 9 11-11-2010 09:49 PM
Switch on K&T wiring - OK to pigtail? fdmillion Electrical 4 01-27-2010 10:15 AM
